S2 levers
S2 levers
Postby gaz_powell » Fri Sep 26, 2014 4:38 pm
I am right in thinking px levers fit S2 ?
I want something with a decent size ball end and am struggling to find any.
I have one in the garage so will try tonight
Gaz
Re: S2 levers
Postby Storkfoot » Fri Sep 26, 2014 5:14 pm
I haven't tried it but I do recall seeing a post from Jason Frost saying that they did.
Re: S2 levers
Postby MK Monty » Fri Sep 26, 2014 5:35 pm
I fitted some dog leg PX ones and they fit fine. I had to trim the edges of the levers as they were slightly fatter than the handlebar casting. the bolt position and size are identical and of course they have a flat join to the handlebar so will not fit a series 3. As with everything else a bit of fettling required but easier than fitting some Lambretta parts.
MK Monty
Re: S2 levers
Postby gaz_powell » Fri Sep 26, 2014 8:02 pm
Thanks gents
didn't get to garage so will check it out tomorrow
G
Re: S2 levers
Postby IaninDorset » Fri Sep 26, 2014 9:16 pm
That's handy to know as finding out with my clutch cable stretching T5, I want to put adjustables on my lever sets although I have been told that Lambretta mechanics are a little easier on the cables than Vespas but being a noob I cannot say if this is the case but I do dislike sloppy cables.
IaninDorset
Re: S2 levers
Postby gaz_powell » Sun Sep 28, 2014 9:49 am
they defiantly do - tried one yesterday
I passed chiselspeed yesterday and picked up a good set of s2 levers - so I could but the anti rattle caps/springs - which the vespa ones dont have.
gaz
Re: S2 levers
Postby Storkfoot » Wed Dec 03, 2014 9:44 pm
I've decided my small hands are struggling too much to cope with a standard S2 clutch lever. I have these type on my Vespa Rally, where I had the same problem with the original levers:
http://www.sip-scootershop.com/en/produ ... _j63960000
I presuming they'll reduce the reach for my small paws but will they pull in the clutch that little bit further?
Re: S2 levers
Postby MK Monty » Wed Dec 03, 2014 10:25 pm
These are the PX ones I got. They were originally bright red scooter emporium ones that I stripped the paint off only to find the paint was hiding the pretty rough sand casting. They polished up OK once the flash joins were removed with a file. They are a good fit and I have no problem with the clutch as the bighting point seems to be the same in the middle of the stroke with normal 2-3 mm free travel at the start. No more pain at the base of my thumb with the leaver a good 1 inch closer than a standard lever
MK Monty
Re: S2 levers
Postby Storkfoot » Thu Dec 04, 2014 11:28 pm
Thanks very much for taking the time to post that, MKM. Much appreciated. I'll definitely get one now.
Re: S2 levers
Postby gaz_powell » Fri Dec 05, 2014 12:18 am
I ended up with standard ball end ones but looking at them they look great ........mmmm .......a change is a coming !
Re: S2 levers
Postby Dimitrios_231 » Sun Dec 07, 2014 12:45 pm
This is what I do to my levers,
this way I can add balls :)
Dimitrios_231
