maddogmadox wrote:Is the top of the clutch touching on the kick start inner, that's a very good possibility. i always put felt marker on my top steel and my kick start inner now , then put the side casing on and kick it over then take it off to check for marks on the two parts to see if any marking has occurred, Its surprising how they can still touch even when the kick start has been shimmed correctly and the face has been ground,
what clutch are you using by the way ?
hullygully wrote:best split the casings, as you've had her for 4 yrs..... never mind how many miles she did with previous owner
hullygully wrote:don't forget the springs:-
the lengths & diameters
could use a thinner top pressure plate to give the plates more freedom
ULC Soulagent wrote:hullygully wrote:don't forget the springs:-
Mb clutch springs at that
hullygully wrote:try Reedsped red plates, cheaper than surflex, but last longer & are grippier than a wifes hand on her husbands wallet
Toddy wrote:hullygully wrote:try Reedsped red plates, cheaper than surflex, but last longer & are grippier than a wifes hand on her husbands wallet
That’s your excuse then
Fast n Furious wrote:Check the fingers on the outer and inner bells for signs of wear where the clutch plate ears contact. If they are worn bad then ideally new parts wills be required. You can dress them up with a file to allow the plates to slide and separate more easily.
Users browsing this forum: Bing [Bot] and 66 guests
