Speedo drive bush thread.
Postby corrado » Fri Apr 19, 2019 10:50 pm
Does anybody know the thread size of the speedo drive bush?
corrado
Re: Speedo drive bush thread.
Postby Warkton Tornado No.1 » Fri Apr 19, 2019 11:51 pm
I'm nowhere near anywhere I can check, but believe it is the same thread as the chain case cover drain/level plugs, that being M16 x I.5
You're bound to have one of those to check with ;)
Postby corrado » Sat Apr 20, 2019 12:07 am
I'll check tomorrow. Sods law that I've got a 16 x 1.5 die but no tap. Cheers.
corrado
Postby Warkton Tornado No.1 » Sat Apr 20, 2019 2:48 am
I should have the tap, if you need to borrow it.
I'm fairly sure that I used a level plug to blank off a speedo drive hole for racing :oops: I soon realised that weight saving was a lot more important than adding bling......
Postby rossclark » Sat Apr 20, 2019 10:01 pm
Yep think that's right M16x1.5 - I think I also have the tap somewhere if you're stuck.
