Seen this...?
Seen this...?
Postby Andy B.L.C. » Mon Apr 08, 2019 9:28 pm
Andy B.L.C.
Re: Seen this...?
Postby Fast n Furious » Tue Apr 09, 2019 1:22 am
They've been around for about 4 years now.
I considered getting one a while back but its a bit pricey for an ignition that cant be adjusted "on the fly" which is what I really wanted.
Re: Seen this...?
Postby Toddy » Tue Apr 09, 2019 5:50 am
Fast n Furious wrote:They've been around for about 4 years now.
On the Fly ?
Re: Seen this...?
Postby hullygully » Tue Apr 09, 2019 8:05 am
:lol: :lol: :lol:
Re: Seen this...?
Postby Fast n Furious » Tue Apr 09, 2019 3:38 pm
On the Fly ?
On the fly means adjusting it whilst the engine is running. Online rather than offline if you see what I mean.
Re: Seen this...?
Postby Toddy » Tue Apr 09, 2019 3:55 pm
On the Fly ?
I see , You can still set as normal via strobe , but adjust on the app or set your own curves to suit your tune / riding
Re: Seen this...?
Postby shane BBoys » Tue Apr 09, 2019 5:04 pm
Is this not something Eden was trying out a while ago?
Cheers Shane.
shane BBoys
Re: Seen this...?
Postby Fast n Furious » Tue Apr 09, 2019 5:17 pm
With these offline type units you have to disconnect the supply power before the app software will communicate with the processor of the CDI. (offline). The programmable CDi's that have multiple switchable programs stored in memory that I have tried, can only be changed over with the power off. The ability to modify the timing while running within a particular rev band makes setting up for max power within that band a doddle on the dyno.
Re: Seen this...?
Postby Toddy » Tue Apr 09, 2019 5:43 pm
You can change the curve on this one which you programme into the unit via the app also
You can adv/ ret with the app
Re: Seen this...?
Postby Toddy » Tue Apr 09, 2019 5:44 pm
shane BBoys wrote:Is this not something Eden was trying out a while ago?
Cheers Shane.
Shane , Yes and still is I believe
Re: Seen this...?
Postby hullygully » Wed Apr 10, 2019 11:18 am
can you do it whilst your wringing its kneck with your laptop between your legs :lol: :lol:
Re: Seen this...?
Postby Toddy » Wed Apr 10, 2019 11:33 am
hullygully wrote:can you do it whilst your wringing its kneck with your laptop between your legs :lol: :lol:
Cmon mickey keep up lap top sets curves so you don’t need while ringing its neck ;)
Re: Seen this...?
Postby hullygully » Thu Apr 11, 2019 12:01 pm
derrrrrrrrrrrrrrrrrrrrr 6-fingers :x
