More air into air box
Postby WOO » Tue Mar 05, 2019 3:14 pm
Good afternoon
My early series 2 is now upgraded from a 125 to a 175 with a 22mm scootopia carb.
All runs nice with the original air scoop taken off so i have got a much larger GP scoop which will fit.
My air box has an 18mm inlet, i hear that you can drill holes in the box to improve air intake as well.
If that is the case does anyone know how many holes to drill, what diameter and presumably drill them near the top of the air box.
cheers
WOO
Re: More air into air box
Postby superhooper » Tue Mar 05, 2019 6:06 pm
Fit a GP airbox. It has a larger opening I believe
superhooper
Postby Hoss » Wed Mar 06, 2019 12:39 am
I drilled a lot of holes in the forward face of airbox about 12mm holes I think. I Also cut out as much of the baffle/inlet tube inside the airbox as I could
Hoss
Postby hullygully » Wed Mar 27, 2019 11:02 am
Try random 10mm holes on both sides of the filter box, then they're hidden by the tank & toolbox,
don't forget a quality breathe sweet airfilter also, aswell as removing the internal swan kneck, 8-)
but JET UP TO SUIT :shock:
Postby lozmondo » Wed Mar 27, 2019 5:57 pm
theres one on ebay already drilled...not sure who is selling it though :? :D
lozmondo
Postby Knowledge » Wed Mar 27, 2019 10:11 pm
Try buying one of these to cut your own holes. They are a lovely tool to use and perfect for this kind of job.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F362061659406
No distortion and no burrs to clean-up, as it cuts a perfect circle every time.
Postby Rich Oswald » Mon Apr 01, 2019 12:32 pm
lozmondo wrote:theres one on ebay already drilled...not sure who is selling it though :? :D
If it is the one I saw, it is sold.
Postby daniel whiteley » Mon Apr 01, 2019 9:51 pm
Just modify the inlet to be 50mm like the bgm ones , when you cut the original neck off the inner baffle will come away easy enough
daniel whiteley
Postby lozmondo » Tue Apr 02, 2019 7:06 pm
Nope :D
lozmondo
Return to Carburettors
Users browsing this forum: No registered users and 59 guests
