extra long engine bolt
Postby kdodd » Sun Mar 31, 2019 5:01 pm
anyone know of an extra long engine mount bolt, need 350-355 long as got rear disc bracket
many thanks
kdodd
Re: extra long engine bolt
Postby piskie » Sun Mar 31, 2019 6:41 pm
Let me know your address I will send you one
Andy vass
piskie
Postby kdodd » Mon Apr 01, 2019 7:27 pm
pm sent thanks
kdodd
Postby piskie » Tue Apr 02, 2019 10:24 pm
Let me know where to send it foc
piskie
Postby Knowledge » Sat Apr 06, 2019 4:37 pm
Are you sure you want to connect the rear disc bracket to the engine bolt?
Unless you have some sort of “give” in the disc arm, then you will put the arm under a lot of strain when the suspension compresses.
It would be better to fit the disc support arm to the outside of the engine mount, as this rotates around the engine bolt. A exhaust clamp makes a good fixing to the outside of the engine mount.
Postby piskie » Fri Apr 12, 2019 11:21 am
Sent long bolt hope you received ok if u need any more or extra nuts let me know
piskie
Postby Fast n Furious » Fri Apr 12, 2019 10:26 pm
Knowledge wrote:Are you sure you want to connect the rear disc bracket to the engine bolt?
I suspect the extra long engine bolt is used on the type of radius arms which have a bearing around the engine bolt fulcrum. This type is supposed to resist the rear wheel torque twist on the engine mounts which you don't get with the outer engine mount types.
