Poor starting from cold and poor 1/8 throttle setting
Postby Norfolk » Sun Mar 31, 2019 9:41 pm
I am currently running Mugello 186, Varitronic ignition set at 19 degrees, dellorto 26 carb, main 104, pilot 48, atomiser av266, needle x7 second clip, slide 40, choke 70, Ancillote exhaust.
If you are still with me the problem is :- (1) starting from cold, it may start on first kick or takes ages despite changing spark plug, once it does start for the remainder of the day it always starts. :- (2) when on 1/8 to 1/4 throttle it runs like a pig whether stationary or under normal drive conditions. (Four stroking ? ) Otherwise performance is excellent pulling well both one and two up.
I have read camlam suggested carb settings, but which do you suggest I change first, and regarding the various jets do I need jets with higher or lower numbers.
P.s. The choke is working fine and I follow the recommended throttle positions when starting.
Thanks in advance
Norfolk
Re: Poor starting from cold and poor 1/8 throttle setting
Postby shane BBoys » Sun Mar 31, 2019 9:57 pm
Hi.
I have read somewhere 50 pilot & 50 choke.
Cheers Shane.
shane BBoys
Postby Rich Oswald » Mon Apr 01, 2019 12:32 pm
Could be all sorts but I really don't think it is Jetting with what you have. No throttle at all for cold starting. Spark plug gap is a possibility. Is the choke working properly and fully? Could try 70 choke Jet. Could be electrical and the spark is not strong enough initially.
Postby coaster » Mon Apr 01, 2019 1:06 pm
Rich Oswald wrote:Could be all sorts but I really don't think it is Jetting with what you have. No throttle at all for cold starting.Rich'
+1 for that, fundamental error wringing the throttle when starting, not saying that is the problem but it very often is.
Postby MickYork » Mon Apr 01, 2019 3:29 pm
You could try advancing your timing. 19* seems too retarded for a Varitronic.....think it should be set at 21/22.
Postby Norfolk » Mon Apr 01, 2019 8:41 pm
Thanks for giving me a few pointers, I will try the timing although I seem to recall it recommended to retard the timing to prevent piston damage.
Norfolk
Postby CHRIS in MARGATE » Mon Apr 01, 2019 8:59 pm
Don’t believe all you read. Advance that timing. Lessen the plug gap. Keep the throttle shut.
Have you compression tested the engine; rings might be worn?
Postby coaster » Mon Apr 01, 2019 11:16 pm
19 degrees is already as far advance as you really want to go with fixed ignition and modern fuel, many use 17 degrees.
Postby MickYork » Tue Apr 02, 2019 7:25 am
coaster wrote:19 degrees is already as far advance as you really want to go with fixed ignition and modern fuel, many use 17 degrees.
it's a Varitronic, which will retard up to 12 degrees.
Postby coaster » Tue Apr 02, 2019 12:51 pm
Yes, I missed that it had varitronic but Id not heard they retard that much :shock: thought it was about 6 degrees :? Either way, I doubt if it would affect starting that much.
Return to Carburettors
Users browsing this forum: Bing [Bot] and 49 guests
