CHRIS in MARGATE wrote:17 degrees BTDC timing is way back from spec when it was 23 or 21.
I would start by retiming to 19 BTDC.
After that it's go on a diet and lose 8 stone !!
That's how much I have gained since I was a teenager.
rossclark wrote:Stroke and rod length are unrelated, 57/107, 57/110 , 57/116 the piston moves 57mm in all cases the only thing that changes is the position of the piston relative to the base face of the casing.
Changes to stroke and rod length need to be taken in the round and the required packers / gaskets and port timing adjustments need to be carefully calculated to ensure the desired results.
