Can any body recommend a good fast flowing petrol tap @ a fare price.
Stag
ToBoldlyGo wrote:If you have trouble fitting a tap and find the silent block interferes with it the Scootopia tap is a way around it. It sits higher up and gives you that little bit more clearance.
HxPaul wrote:ToBoldlyGo wrote:If you have trouble fitting a tap and find the silent block interferes with it the Scootopia tap is a way around it. It sits higher up and gives you that little bit more clearance.
Plus they have a reserve that is an equal flow to the normal flow(most dont)and they are switched on as normal,but with a reasuring "click".
gaz_powell wrote:Yep - I've extended 3 scootopia pipes to increase the reserve as they are on TS1s
HxPaul wrote:gaz_powell wrote:Yep - I've extended 3 scootopia pipes to increase the reserve as they are on TS1s
But you have to alter the reserve pipe on OMG fast flow taps because there to long.
rossclark wrote:I got a Scootopia tap, out of the box the fuel flow was dismal - after I'd added 4l of fuel it took more than half an hour to empty the tank. On dismantling the tap the rubber was well out of line and blocking the holes. That sorted, it was flowing half a litre in about 50s.
On later reason to disconnect the fuel pipe I found that even on off the fuel flowed, again I had to drain the tank, dismantle the tap and this time I found the centre hole of the three in the rubber had distorted and the rubber lip had split. Paring the lip of that hole with a blade and reassembling it seems to have fixed it but my confidence in these taps is low.
