degrees c or f? I only see about 85c where mine is.coaster wrote:I gave up with the under plug sensor rings too as I had plugs work loose on a few occasions and when a plug blew out completely I thought thats enough. The problem is that the cylinder head reacts slowly to changes in combustion temperature so you need to be reading the temp as close to the plug as possible. I used my dremel to create a flat area as close to the plug as I could get but allowing room to get a plug socket on. I then drilled a hole and taped it to accept the threaded part of the sensor that normally screws into the ring. I'm seeing temps a few degrees less than I was before, around 170-180ish.
Scooterdude wrote:coaster wrote:I gave up with the under plug sensor rings too as I had plugs work loose on a few occasions and when a plug blew out completely I thought thats enough. The problem is that the cylinder head reacts slowly to changes in combustion temperature so you need to be reading the temp as close to the plug as possible. I used my dremel to create a flat area as close to the plug as I could get but allowing room to get a plug socket on. I then drilled a hole and taped it to accept the threaded part of the sensor that normally screws into the ring. I'm seeing temps a few degrees less than I was before, around 170-180ish.
Roughly what difference in temperature do you see with the sensor in its new position rather than under the plug?
Covboy wrote:Rather than the magnet, I use the SIP electrical pulse cable that screws into the original speedo drive. Its works very well
