EddieStone wrote:I'd go for the AF kit with a mid weight flywheel. Can't see much point in variable unless you're tuning the balls off it. The standard electronic kit will transform it enough.
Go for the basic electronic kit and put the rest of the money towards a decent a front brake.
coaster wrote: I would be tempted to pick up a cheap new or even used SIL stator and send it to Anthony Tambs (I'm not sure if he is on here but you will find him on Face Book) he renovates stators with new coils and wiring and his work is second to none and very reasonably priced. Add in a decent CDI and even if you added one of the variable ignition modules available you will get a lot of change out of £200 including the flywheel. That's what I would do anyway
