dscscotty wrote:0.8- is ok on race spec motors, we run 0.8 on production class with av gas controlled fuel etc, road motors a side of caution is advisable, some people read to much!
HxPaul wrote:The problem with road going scooters is,there not rebuilt on a regular basis and a build up of carbon in the combustion chamber of the head and the top of the piston can bring them very close together,that and the close squish of less than 1.00mm and they could be touching.
johnnyXS wrote:HxPaul wrote:The problem with road going scooters is,there not rebuilt on a regular basis and a build up of carbon in the combustion chamber of the head and the top of the piston can bring them very close together,that and the close squish of less than 1.00mm and they could be touching.
I've been thinking about this and in my experience engines are to a large extent self cleaning .
Yes carbon can build up on the piston crown but it can only build up in the space that we give it. Using an engine through its full range and getting it thoroughly warm will prevent carbon build up to a large extent. Its the slow running pottering around Town commute milage that is so detrimental to engines
Once the squish area is filled with carbon on top of the piston it cannot build any further due to the constant detonation and squishing . The more squish depth we allow between the piston crown and the head ....the more room we allow for carbon to build up. Once there is any appreciable carbon build up I would imagine it would have the effect of increasing the compression ratio ...giving potentially more power ...on the other hand the rough surface on top of the piston will slow down the flame travel under detonation which will have a slightly negative effect on power.
Come this August I will have been wrenching on Scooter, motorcycle and car engines for exactly 50 years and in all that time I have never read or heard of a single instance where carbon build up has been the direct cause of engine failure.
I'd be interested in others experience on this though
a-teamlambretta wrote:Just changed head on an imola top end, squish is coming out at 0.80. Is this too close?. I am using packers top and bottom and don't want to add a gasket at the top, was hoping to get away without buying another packer. Cheers Simon
