a-teamlambretta wrote:......I need to know what slide,needle, atomiser,main,choke and idle jets.
foremanbob wrote:isnt anything like this is it? this only happened as the throttle was opened up
This was a dodgy pickup on a BGM stator that I replaced with a Ducati pickup, and all was good
https://www.youtube.com/watch?v=A8eaScGexBA
johnnyXS wrote:24 degrees at fast idle is I believe max recommended advance .Your particular scooter spec may not be able to fully utilise that much total advance
I would be tempted to back the advance of 2 degrees and try that first to see if there was any improvement before messing with the jetting.
http://www.lambretta.co.uk/downloads/varitronic-fitting.html
dscscotty wrote:When you say reed 240, what has been done to the cylinder?, has a boost or boost ports been added? Piston modifications? 150 main seems a little big?
Fred wrote:I'd come down on the main to 140 -145 see if it revs out
weeks wrote:dscscotty wrote:When you say reed 240, what has been done to the cylinder?, has a boost or boost ports been added? Piston modifications? 150 main seems a little big?Fred wrote:I'd come down on the main to 140 -145 see if it revs out
As your only revving out on the stand this has got to be the easiest try
missing lynx wrote:it could be the exhaust
Wack wrote:You will find that on a Varitronic , it hits a brick wall in neutral and will not rev out almost feels like you have blocked the exhaust. Wait till you get out on the road and I'm pretty sure it won't do it.
