Resonating Through The Seat
Postby ROClarke » Wed Mar 10, 2021 7:27 pm
I have recently fitted a SST 265 to my GP the engine is fitted with the Casa Expansion Box.
At certain revs I feel the resonanting through the seat and can feel it when I reach down and touch the bodywork.
As the revs increase it disappears.
I have checked usual suspects manifold touching frame,engine touching side panel and even loosened off the engine mount bolt,all to no avail.
I am wondering if it is simply the sound waves coming off the expansion box and causing the annoying tingling sensation through the scoot.
Has anyone any idea what it might be ?
ROClarke
Re: Resonating Through The Seat
Postby coaster » Wed Mar 10, 2021 10:16 pm
Is your airscoop touching the seat frame? I have that problem with my GT240 where the scoop is in heavy contact with my Anciotti seat. Only a problem around 30 mph but very unpleasant :(
Postby MickYork » Thu Mar 11, 2021 7:51 am
What engine mounts are you using ? some of the more expensive ones are reportedly very hard, causing vibration issues.
Postby missing lynx » Thu Mar 11, 2021 1:55 pm
Assuming you have got a folding seat are the sides of your seat frame touching the frame loop? And have you used nylon washers when you fixed the seat? If you've got a bolted down one then they will vibrate if you've got a vibee engine but I would check for any contact points between the engine and the frame
Postby ROClarke » Thu Mar 11, 2021 6:25 pm
coaster wrote:Is your airscoop touching the seat frame? I have that problem with my GT240 where the scoop is in heavy contact with my Anciotti seat. Only a problem around 30 mph but very unpleasant :(
I don’t have an air scoop mate
ROClarke
Postby ROClarke » Thu Mar 11, 2021 6:26 pm
MickYork wrote:What engine mounts are you using ? some of the more expensive ones are reportedly very hard, causing vibration issues.
The mounts are Casa as supplied with the engine,I do not know if they are particularly hard mate.
ROClarke
Postby ROClarke » Thu Mar 11, 2021 6:31 pm
missing lynx wrote:Assuming you have got a folding seat are the sides of your seat frame touching the frame loop? And have you used nylon washers when you fixed the seat? If you've got a bolted down one then they will vibrate if you've got a vibee engine but I would check for any contact points between the engine and the frame
Hi Mate
Fitted a replica seat from Beedspeed the rubber mounts where it touches the frame where horrible plastics and where actually taking the paint off so replaced them with some soft rubber I had lying around.All the bolts have rubber washers,but the vibration persists grrrr !
ROClarke
Postby Mr G in NYC » Thu Mar 11, 2021 11:49 pm
Get an air hawk seat cushion and pop it on top
of your exist seat , air cushion sections should
solve you feeling the Vibrations . 8-)
Postby ROClarke » Fri Mar 12, 2021 9:50 pm
I had the sear off today and think I can improve the rubber washers by having them both nut and bolt side of the seat mount.
ROClarke
Postby Andy B.L.C. » Sat Mar 13, 2021 12:08 am
Rubber plumbing washers... Cheap as chips from all possible suppliers, use with/under all & any seat fittings... ;)
Andy B.L.C.
Postby Covboy » Sat Mar 13, 2021 8:15 am
With the scoot off the stand and you sat on it does any part touch the frame - you will need to get someone to look for you
Postby ROClarke » Sat Mar 13, 2021 4:38 pm
Andy B.L.C. wrote:Rubber plumbing washers... Cheap as chips from all possible suppliers, use with/under all & any seat fittings... ;)
You read my mind
ROClarke
Postby ROClarke » Sat Mar 13, 2021 4:41 pm
Covboy wrote:With the scoot off the stand and you sat on it does any part touch the frame - you will need to get someone to look for you
Hi Covboy
I am sure nothing is touching the frame.It is hard to explain as it is not a vibration and disappears at high revs.
But is there at normal speeds.
I am going to try rubber tap washers top and bottom of seat fixing but feel it may need something softer.
ROClarke
Postby Storkfoot » Sat Mar 13, 2021 6:05 pm
Do the vibrations come through the handlebars too?
How is your exhaust mounted? What engine mounts do you have?
Postby ROClarke » Sat Mar 13, 2021 6:45 pm
Found it !
I have a cheap Pegasus copy seat and the hinge pin is a very loose fit in the hinge.It is resonating like a bee in a jam jar !
Thanks for all your help and advice chaps.
ROClarke
Postby ROClarke » Sun Mar 14, 2021 8:12 pm
Storkfoot wrote:Do the vibrations come through the handlebars too?
Bugger,thought I had found it with seat hinge issue but it’s still there. Engine mounts are the ones that came with the engine.
To answer your other question,there is no vibration through the handle bars.
ROClarke
Postby Leotech » Sun Mar 14, 2021 8:20 pm
My series 2 right hand rear floor board resonated at about 4500-5500 rpm when I scooped it out to allow the fitment of an expansion pipe. It was very annoying especially as everywhere I seemed to travel with my mates was 60mph which was right at the top end of the resonation. If I went faster the vibration stopped. I made a stiffener and bolted it to the underside of the floor board and it cured it.
Leotech
Postby Storkfoot » Sun Mar 14, 2021 9:08 pm
I was thinking of loose forks but the vibes would come through the handlebars in that case.
I have read that some of the super engines have very firm mounts that may be more useful on a race track. I’d suggest you ask the engine supplier/ builder as such mounts on a really powerful engine may produce such vibrations at certain resonances.
If you could post some pictures of the mounts close up and the exhaust mounting points, maybe someone can comment further.
Postby ROClarke » Mon Mar 15, 2021 10:13 pm
Yes I think you might be right about the silent blocks.
I spoke to JB tuning today and they sis said they fit BGM blocks to the engines they fit from CASA.
I think the race ones you are referring to are solid,mine have the normal 3 holes.
JB man said it is probably resonating off the expansion box which is what I have always had a suspicion of,so I am going to try wrapping the exhaust in exhaust wrap and stick sound deadening under the floor.
ROClarke
Postby Storkfoot » Thu May 14, 2026 10:05 pm
ROClarke wrote:I have recently fitted a SST 265 to my GP the engine is fitted with the Casa Expansion Box.
Did you ever get to the bottom of this please?
