Vape sport ignition
Vape sport ignition
Postby a-teamlambretta » Sat Feb 20, 2021 5:29 pm
Anyone using a vape sport ignition?. What have you set your timing at?
a-teamlambretta
Re: Vape sport ignition
Postby Knowledge » Sun Feb 21, 2021 10:14 pm
This is my general advice for fitting advance/retard systems is this.
Fit it, and strope it at high revs and check it is retarding to about 17degrees. If not, adjust the timing. You might find that at tickover it is at about 25degrees, but that isn’t as important as ensuring that the it won’t blow up at high revs.
It is a starting point.
Postby a-teamlambretta » Mon Feb 22, 2021 4:52 pm
Set it at 24degree to regarding to16 degree
Cheers for the help
a-teamlambretta
Postby johnnyjarvis » Sat Mar 04, 2023 1:01 pm
A mate is thinking of fitting a vape sport to his TS1. Its fitted with a TSR touring pipe and sits at 60 at 6000 revs.
When he rides its usually in a group, doesnt go faster than 60-65.
What would his timing retard to at this speed/revs ?
Hes worried that it might not have retarded enough and he might be better off with the road version set at 17 degrees static.
your thoughts...
johnnyjarvis
Postby nsaints » Mon Mar 06, 2023 8:14 am
You'd need to find the technical information on the ignition system, specifically the ignition curve ideally on a graph indicating the timing at given revs
Use that along with the Lambretta Gearbox analyser (free .xls to download via a google search) to know what revs for given speed to know the timing at a given speed
you would need to know what gearbox, sprocket ratio's you are running though..
nsaints
Postby gp200ts1 » Wed Mar 08, 2023 7:22 am
the problem is are the ignition charts available? I know with the scootopia system that the charts do not exist. I emailed scootopia about them and they said they did not know!
gp200ts1
Postby jonw » Wed Mar 08, 2023 5:30 pm
When you buy the SIP Vape ignition it comes with an instruction booklet which illustrates the timing curve showing very clear and specific values at varying revs.
Unfortunately I can't find any link online, only to the Vespa version.
jonw
Postby Wack » Fri Mar 10, 2023 9:36 pm
I think the Vespa chart is exactly the same for a Lambretta as it’s the same system but with a different stator backplate.
Postby jonw » Mon Mar 13, 2023 9:10 am
Wack wrote:I think the Vespa chart is exactly the same for a Lambretta as it’s the same system but with a different stator backplate.
Having fitted one to my P200E and to mates Jet 200 I suspect you are right but can't confirm whether the CDI and ignition maps are the same.
jonw
Users browsing this forum: Baidu [Spider] and 54 guests
