AC vape ignition and SIP speedo
Postby lozmondo » Thu May 28, 2020 3:05 pm
Anyone running the above? if so which setting are you using in the rev counter menu?
many thanks
lozmondo
Re: AC vape ignition and SIP speedo
Postby Toddy » Mon Jun 01, 2020 2:56 pm
lozmondo wrote:Anyone running the above? if so which setting are you using in the rev counter menu?
many thanks
Loz moved Topic in here may get more response hopefully ;)
Postby Mike-Allen » Tue Jun 02, 2020 2:56 pm
many thanks
I’ve just fitted the AC vape ignition and sip speedo to my series 1 build. I found setting it to 6 from the preset 3 gave the best results for the Rev counter.
Mike
Mike-Allen
Postby lozmondo » Tue Jun 02, 2020 5:24 pm
Cheers Toddy you were proved right
Many thanks Mike, after playing around I found 6 worked fine.
lozmondo
Postby Toddy » Tue Jun 02, 2020 5:25 pm
lozmondo wrote:Cheers Toddy you were proved right
No worries mate and thanks Mike
