Is it neccessary to lap the flywheel to the crank?
If the answer is yes,why are they not marketed as a pre-matched pair?
Toddy wrote:I always lap mine to suit so the flywheel is a good fit on the taper , matched pairthat’s being sensible
bsso78 wrote:Toddy wrote:I always lap mine to suit so the flywheel is a good fit on the taper , matched pairthat’s being sensible
Do you lap your toupe to your napper in case of string winds?
Toddy wrote:bsso78 wrote:Toddy wrote:I always lap mine to suit so the flywheel is a good fit on the taper , matched pairthat’s being sensible
Yes with gorilla glue off wiggy in your village
