Scooterslag wrote:Might be worth having a bit more work done on your existing engine, maybe a change of sprockets and better carb/pipe combination might release some more performance? quite a few people have tweaked their SR kits with good results and will save you a arm and a leg forking out for a new engine/kit etc. Paul
Mel K wrote:Scooterslag wrote:Might be worth having a bit more work done on your existing engine, maybe a change of sprockets and better carb/pipe combination might release some more performance? quite a few people have tweaked their SR kits with good results and will save you a arm and a leg forking out for a new engine/kit etc. Paul
This is very good advice, good carb and pipe , ones that will perform well on a big block kit if it's still not what you want , it will save you thousands ! If it ain't broke don't fix it, but you can tweek it ; )
MickYork wrote:I'ld be inclined to get your casings adapted to take a 200 stud pattern. The benefits are obvious (no substitute for size !!) with the added bonus of the casings being matched to any base gasket so your kit will be matched to the casings for you at very little extra cost.
MickYork wrote:Whereabouts are you?
Plenty of builders up and down the country.
Adam_Winstone wrote:Banbury, Oxford and Thame all have very active scooter clubs that you could chat to
Adam (Oxford Roadrunners SC)
mainstand wrote:I'd get a GT186 kit on a small block personally. Everyone I know who runs one has done 1000's of miles faultlessy. (well the kits have been faultless)
Eden wrote:watch this to find out, give it a few mins...
Eden wrote:this is video of a mildly tuned 230 version of the big block in the camera scooter
Users browsing this forum: Baidu [Spider], Google [Bot] and 85 guests
