Casa PowerFlow Air Filter
Re: Casa PowerFlow Air Filter
Postby Timexit17 » Tue May 29, 2018 6:26 pm
It runs very well -all checked with Paul Baker at ARP race tech and unchanged from earlier filter (breath sweet).
CHT rarely goes over 88 when riding and 105 when standing still.
Timexit17
Postby Bilko » Tue May 29, 2018 9:48 pm
I'm considering one of these, but I read that small filters restrict performance?
Any info would be appreciated.
Bilko
Postby Timexit17 » Tue May 29, 2018 9:59 pm
The theory is actually these are supposed to be the least restrictive of all filters -and they are hardly 'small' - I'd say the surface area is certainly larger than a standard filter.
My breath sweet filter's jetting was rich in comparison for instance.
Timexit17
Postby Bilko » Tue May 29, 2018 10:15 pm
Excellent, thanks Tim.
Just what I wanted to hear. Judging for size isn't my strong point!
Bilko
Postby ROClarke » Wed May 30, 2018 10:29 am
Got mine from VE and came next day.
Really looked foward to fitting it to my TS1, unfortunately as carb is right hand side,tool box has to go and the the rubber elbow is compressed by side panel when fitted :cry:
Ideas anyone ?
ROClarke
Postby Fast n Furious » Wed May 30, 2018 2:46 pm
I hope that 105 is a typo Tim?
Like Mick sez...... Very lean for a 225? :roll:
Postby Fast n Furious » Wed May 30, 2018 2:54 pm
ROClarke wrote:Got mine from VE and came next day.
Ideas anyone ?
With a TS1 you don't have to discard the toolbox.
There are aftermarket manifolds available to get around this issue, but a cheap way is to carefully and neatly dent inwards that bottom corner of toolbox that is causing the restriction with a suitable small hammer. A touch up to the paint work and all works well.
Unfortunately, the side panel issue is another matter. Just depends what carb you is using.
Postby Timexit17 » Wed May 30, 2018 5:04 pm
Fast n Furious wrote:I hope that 105 is a typo Tim?
The 105 has been on the bike for the past year and used a fair amount with a breathe sweet filter.
It was dyno'd again by Paul Baker (SRP race tech) and everything tested and the needle changed to the leaner X7, so I'm confident even if, in theory, it looks very lean.
I'll be checking the plug colour and as always after re-jetting I kept an eye on temps all the way back (45 miles) and all was fine.
Timexit17
Postby Paul_from_Thornbury » Thu May 31, 2018 10:07 am
Quick Question for anyone who's got a Casa Powerflow, what are the dimensions of the oval entry flange into the Filter?
Also what is the height of the blue filter material to check if it fits in my tank cutout?
I use one of the BGM armadillo elbows as my engine is a terrible starter without the drain in the rubber elbow, the Casa elbows don't have the drain.
Just wondering if the 50mm filter diameter when squeezed on my Armadillo would suit the Casa Oval entry?
Paul_from_Thornbury
Postby Paul_from_Thornbury » Thu May 31, 2018 12:57 pm
OK, got my answer, no the Casa filter is too big.
Hopefully they'll produce an elbow with a drain.
Paul_from_Thornbury
Postby Bilko » Fri Jun 01, 2018 2:16 pm
I'm wondering if one will fit my carb. There's only about a 1cm gap from the bottom of the carb to the side panel. Does anyone know the depth of the hose?
Bilko
Postby ROClarke » Fri Jun 01, 2018 9:50 pm
Ideas anyone ?
Thanks for the tool box tip F&F
Carb is a delly 30 phbh
ROClarke
Postby ROClarke » Fri Jun 01, 2018 9:54 pm
Bilko wrote:I'm wondering if one will fit my carb. There's only about a 1cm gap from the bottom of the carb to the side panel. Does anyone know the depth of the hose?
The hose is 55mm deep, but you loose 10 mm pushing over the plastic bell on the dellorto carb.
ROClarke
Postby Bilko » Fri Jun 01, 2018 10:26 pm
Thanks for the reply. Saved me a few quid. I was hoping this was going to fit.
Bilko
Postby ROClarke » Wed Jun 27, 2018 1:45 pm
Ideas anyone ?
Hi Mate
Not happy with the tool box solution as the rubber elbow hits the side panel still.
Who or what would you recommend for the L/H manifold option ?
ROClarke
Postby Feersum Injun » Wed Jun 27, 2018 4:14 pm
ROClarke wrote:
Fast n Furious wrote:Who or what would you recommend for the L/H manifold option ?
LTH do one... 'Linke Nummer'... about 136 euro though... they are good though, lots of room and the carb sits level coming off the barrel
Here's a photo of mine under construction... I'll take another photo later showing complete...
ImageIMG_9655 by Nick Wilde, on Flickr
Feersum Injun
Postby lozmondo » Wed Jun 27, 2018 9:09 pm
im using a filter sold by Chiselspeed.
https://www.chiselspeed.co.uk/index.php ... uct_id=564
seems to work well and the clearance issue...isnt one :D
lozmondo
Postby gp200ts1 » Thu Jun 28, 2018 2:17 pm
The chiselspeed one is available on eBay in the same packaging from lots of dealers average price is £8 to £12 inc postage
gp200ts1
Postby Feersum Injun » Thu Jun 28, 2018 3:58 pm
Another photo of the left-hand manifold....
ImageIMG_9776 by Nick Wilde, on Flickr
It does come out quite low in relation to the running boards but shouldn't matter if you're looking to use an under panel filter...
ImageIMG_9782 by Nick Wilde, on Flickr
Feersum Injun
Postby bike grim » Thu Jun 28, 2018 6:41 pm
Have you used a reed packer Nick?
