Heads up folks
Standard Ex-Box exhausts back in stock as of this afternoon
https://www.supertune.co/
Adam_Winstone wrote:My non ST ExBox isn't too loud. Sure the ST needs the tail can IMO but the regular ExBox works for me... so much that I've bought a second one.
Don't get me wrong, they're louder than a number of other clubmans / Super clubmans but they also flow better and allow higher revving kits to work correctly, where some others strangle the revs before many kits come into the power.
Horses for courses.
Horses for courses.
superhooper wrote:The panel on my GP kept getting knocked off . I discovered that it was hitting the silencer bracket bolt. Your suspension may need hardening up as that is how i solved issue on mine.
Regards
Roy
jonoy wrote:superhooper wrote:The panel on my GP kept getting knocked off . I discovered that it was hitting the silencer bracket bolt. Your suspension may need hardening up as that is how i solved issue on mine.
Regards
Roy
Thank you for the reply.
I did that and went over a speed bump several times back and forth
and it appears to have resolved it.
Users browsing this forum: No registered users and 61 guests
