I have two sets of clutch springs. One set is around 35mm tall and the other are 28 mm. The ones that are 35mm I presume are standard and the others are the stronger type is my theory correct?
Cheers Simon
ULC Soulagent wrote:Mb=34.30/2.10/14.50
Mb=37.15/2.10/14.00
BGM STRONG 32.15/1.65/8.70
BGM MEDIUM 32.13/1.90/13.50
BGM SOFT 32.14/1.70/11.60
Above are the springs that I use and measurements are uncompressed length/ spring thickness/ compressed length
Warkton Tornado No.1 wrote:ULC Soulagent wrote:Mb=34.30/2.10/14.50
Mb=37.15/2.10/14.00
Unless a material other than 'music wire' has been utilised, there's something strange if a spring wire diameter of only 1.65 mm can be stronger than similar springs of the same manufacture with greater wire diameters....
