Standard GT200
Standard GT200
Postby pauLI » Wed Mar 30, 2016 9:11 am
Standard GT200 engine,
standard carb is a delly 20mil & 38mm pipe
I don't want anything other than the standard engine performing to its best
what carb would be best suited? if I switch the pipe to a 42mm af clubman
thanks in advance
pauLI
Re: Standard GT200
Postby missing lynx » Wed Mar 30, 2016 12:15 pm
stick with the std carb just up jet and modify your airbox and scoop to allow better air flow and if you've not used a TV200 box before to get to top speed you have to really go for it in 3rd before you change up and I use to do most town riding in 3rd
Re: Standard GT200
Postby Rich Oswald » Wed Mar 30, 2016 1:00 pm
If you want standard performance then why are you changing to a Clubman? If you really must change then why not try one of the new Scootopia 22mm Del Orto copies. You will, as has been said, have to increase your air flow via the scoop.
Re: Standard GT200
Postby pauLI » Wed Mar 30, 2016 2:26 pm
Rich Oswald wrote:If you want standard performance then why are you changing to a Clubman? If you really must change then why not try one of the new Scootopia 22mm Del Orto copies. You will, as has been said, have to increase your air flow via the scoop.
Hi Rich
What I mean was, I don't want to be putting a kit on it but want to maximise the performance of the standard engine (if that makes sense)
pauLI
Re: Standard GT200
Postby Rich Oswald » Wed Mar 30, 2016 6:57 pm
Yes I understand now. The new22mm Scootopia copies are supposedly very good.
Re: Standard GT200
Postby wibblethorpe » Thu Mar 31, 2016 9:03 am
If the motor is running the factory TV 200 gearbox & barrel fitting a larger 22mm carb & clubman could make pulling the tall g/box ratio a chore.
My understanding was the larger carb & changes to the exhaust for the GP made for a revier motor hence g/box ratio change(5.2 as opposed to 4.4).
wibblethorpe
Re: Standard GT200
Postby pauLI » Thu Mar 31, 2016 11:17 am
wibblethorpe wrote:If the motor is running the factory TV 200 gearbox & barrel fitting a larger 22mm carb & clubman could make pulling the tall g/box ratio a chore.
so based on this, would you suggest sticking with the 20mm carb and a 38mm pipe? or fitting a 42mm and up=jetting the carb?
pauLI
Re: Standard GT200
Postby missing lynx » Thu Mar 31, 2016 12:59 pm
thats what I said lol
Re: Standard GT200
Postby pauLI » Thu Mar 31, 2016 2:07 pm
missing lynx wrote:thats what I said lol
I know mate and I asked the other poster to get a second opinion
where would you suggest starting with the jetting?
pauLI
Re: Standard GT200
Postby wibblethorpe » Thu Mar 31, 2016 3:00 pm
Off the top of my head the GT had a 109 main jet. This is all my opinion but why change a factory spec TV 200. Any change's to carb & exhaust will have a detrimental affect on the performance.
Start putting bigger carb/exhaust set up on & you might as well put a different gearbox in to take the final ratio up.
All the standard carb specs are available on this site in table form(I think)
wibblethorpe
Re: Standard GT200
Postby Warkton Tornado No.1 » Thu Mar 31, 2016 3:56 pm
paulLI
I can see your objective was to ask opinions concerning optimising what you already have.
Personally, I see no reason why the substitution of carburetion for the superior Dell’Orto SH2/22 & later/enhanced filter box would suddenly change the characteristics of your current set up & make the engine require more revs. In fact, allied to a proper, well made Clubman type exhaust, set up by somebody that knows what they are doing, the result should be a pleasure to ride.
It appears to me that you are not intent on changing the porting in any way & merely seeking to gain some more torque to increase the flexibility of what you have.
A more efficient exhaust does not necessarily mean that the revs are increased, so you have to choose wisely.
Unfortunately, there are Clubman exhausts & there are Clubman exhausts!
Search on this Forum & there’s every chance that certain UK based manufacturers will be recommended. My own opinion is that you won’t go far wrong with an exhaust from Ralph Saxelby &, by all accounts, Ron Moss. They both have racing pedigrees.
Re: Standard GT200
Postby pauLI » Thu Mar 31, 2016 4:48 pm
Warkton Tornado No.1 wrote:paulLI
exactly that, cheers
pauLI
Re: Standard GT200
Postby wibblethorpe » Sat Apr 02, 2016 8:14 pm
So Paul LI , out of all the replies are you any clearer on what ( if anything ) you are going to do to the TV 200 ??? Interesting topic
wibblethorpe
Re: Standard GT200
Postby pauLI » Sat Apr 02, 2016 9:34 pm
After the replies on here, a number of pm's, a mate asking elsewhere and a few discussions with the GT owners club
The best option for a completely standard engine is to stick with the carb and pipe supplied with the machine.
Thanks all
pauLI
Re: Standard GT200
Postby wibblethorpe » Sat Apr 02, 2016 9:57 pm
Good stuff . You would be surprised at how too few standard 200's are on the road.
wibblethorpe
Re: Standard GT200
Postby TS1-200 » Mon Aug 22, 2016 11:01 pm
I have recently fitted a 22mm dellorto and AF big bore carb to my GT 200 and it has transformed it, pulls the gearing easier. if that helps with your decision, if you want I could let you know the jetting used
TS1-200
