30mm dellorto flat spot
Postby Granty » Sat Aug 08, 2015 6:11 pm
Troops, running an open mouthed 30mm dellorto with a 42mm clubman on a standard, stage 4 ish lump, main jet checked and is an 132.
Doing plug chops today and bike pulls really well through gears up to half throttle. plug a good chocolate colour so happy there.
The trouble is when I get to 3/4 throttle and above there is a big flat spot and the scoot seems to not want to rev out. Again done a plug chop and plug the same colour as before. Do you think the 132 main jet is a bit excessive or could it be the gearing? Comments welcome troops. thanks Grant.
Granty
Re: 30mm dellorto flat spot
Postby MickYork » Sun Aug 09, 2015 11:52 am
132 seems a bit big, try coming down to 120 and see how it performs........keep checking the plug though
Postby Granty » Sun Aug 09, 2015 12:42 pm
MickYork wrote:132 seems a bit big, try coming down to 120 and see how it performs........keep checking the plug though
Thanks Mick - Looking at the jetting charts & looking at the plug -- its perfect (but too perfect) up to half throttle -- I wonder if there is a leaner atomiser in there and he's put a monster main jet in to compensate. Tomorrow morning is strip out day & I will report back to the Board.
It's as flat as a pancake at 3/4 throttle but pulls like feck through the gears up to half / 3/4 throttle. If I get it right this thing will be fast (even with me on it) :shock:
Have a good day Mick - G
Granty
Postby Granty » Mon Aug 10, 2015 9:49 pm
OK troops -- this is what was in the 30mm delly after opening it up today
132 main jet
AV264 atomiser
X7 needle with clip 2nd top
55 pilot
70 choke
40 slide
running with a standard clubman on a 200 lump
Thoughts welcome? Im thinking of going with a AV266 atomiser and dropping the main jet down to 125 for a start
Granty
Postby hullygully » Tue Aug 11, 2015 10:56 am
Wouldn't the AV266 atomisor then be letting more fuel in??? Why dont you try the AS range that are slightly weaker than the AV
Postby Granty » Tue Aug 11, 2015 1:13 pm
Thanks for the feedback -- I normally drive at just over 3/4 throttle and I hope that a smaller main jet and larger atomiser will reduce or irradiate the flat spot at that point where the main jet takes over.
The majority of jetting charts ive seen online or on different forms are using AV atomisers -- I'll report back with an update when the jets arrive -- G
Granty
Postby Granty » Wed Aug 12, 2015 9:56 pm
Made the changes so now running
30mm Delly - Open Mouthed
125 main jet
AV266 atomiser
55 pilot
70 choke
40 slide
Bit boggy just below 1/2 throttle but manageable -- plug a good colour
Opened up to 3/4 throttle for 1/2 mile and no flat spot -- didn't have enough time to plug chop it so maybe the morn night for that.
lets see if I can now keep the carb rubber on & stop it popping off!
Granty
Postby Rich Oswald » Thu Aug 13, 2015 12:04 pm
Just my opinion but your main and pilots look too big. I would think about 120 main and 50 pilot would be about right for a st'd 200,
Postby Granty » Thu Aug 13, 2015 8:34 pm
Rich Oswald wrote:Just my opinion but your main and pilots look too big. I would think about 120 main and 50 pilot would be about right for a st'd 200,
Thanks for the input Rich -- I'll get out this weekend for a blast and check out this main jet - G
Granty
Postby Granty » Thu Aug 27, 2015 9:19 pm
Troops -- seem to have taken out the obvious flat spot now, just looking at the finer details, pulls really well up through the throttle stages -- now running
42mm AF Clubman
2 1/2 turns out
50 pilot
70 choke
40 slide
AV266 atomiser
125 main jet
Is a little lumpy idling so maybe thinking a 1/2 turn in with the mixture screw so only 2 turns out.
What a school day has turned out to be -- :D
Granty
Postby Granty » Sat Aug 29, 2015 6:27 pm
Rich -- Ypu're not going to be far away -- changed to a 50 Pilot and tick over is much improved -- up to 1/2 throttle is bang on but still too rich 3/4 throttle up with a 125. working my way down now -- thanks for your help with this - G
Granty
Postby Granty » Thu Mar 10, 2016 9:20 am
Troops -- eventually got the carb set up & ready to go for real, the last bit of advice sounds a bit dumb but I've only ever had smaller carbs running through the box, I now have a opportunity to try out a 20mm open mouth carb -- quick question.................... is there any difference in driving an 30mm open mouth throttle wise then a 26mm through the box, particularly on using the throttle ie gradual opening up etc?
Cheers Troops - G
Granty
Postby Rich Oswald » Thu Mar 10, 2016 12:42 pm
Granty wrote:Troops -- eventually got the carb set up & ready to go for real, the last bit of advice sounds a bit dumb but I've only ever had smaller carbs running through the box, I now have a opportunity to try out a 20mm open mouth carb -- quick question.................... is there any difference in driving an 30mm open mouth throttle wise then a 26mm through the box, particularly on using the throttle ie gradual opening up etc?
Cheers Troops - G
I would say no to this question unless of course you have a highly tuned kit like a TS1 or RB etc where the power band can kick in quite soon in the throttle opening.
Postby Warkton Tornado No.1 » Thu Mar 10, 2016 5:58 pm
Hi.
Sorry to have joined this thread so late. Your initial set-up was:
132 main jet
AV264 atomiser
55 pilot
70 choke
40 slide
For what it’s worth, going back to your original set up, & advocating one change @ a time, I’d have tried lifting the needle one or two clips whilst keeping the AV264. Then tried dropping the main jet down to 125 or so.
My reasoning is that the bottom end was so nearly right with the AV264 & 132 sounds too big.
However, don't be surprised if you end up with a 45 slide.
Postby Granty » Thu Mar 10, 2016 9:47 pm
Cheers Troops - G
Thanks Rich -- just wasn't sure what the craic would be, its a stage 4 200 lump, nothing mega
Granty
