Has anyone got any jetting advice on a 25mm dellorto running through the air box no filter 225 cast iron, would rather be on the rich side if possible.
Any set up advice greatly appreciated
Thank you.
Cgt75b wrote:I'll reply to my own post how sad is thatfor anyone who needs a starting point
Pilot....50
Atomiser...AQ268
Needle...D26 clip third one down.
Slide......40
Main Jet..102
Float needle valve 250
This is running through the air box no holes, with the filter now, 48 mm clubman.
Users browsing this forum: Bing [Bot] and 49 guests
