B1gD0gu3 wrote:Hi all,
Have recently fitted a VHSH 30mm to my TS1 225. Anyone with any experience of this carb advise on the carbs current set up:
U16 needle
155 Main jet
DQ 268 Atomiser
60 Pilot
50 Slide
300 Needle Vv
Franspeed Supertourer exhaust.
Running without side panel fitted but will be fitting once a hole is made in it.
I have changed the Main jet from 165 as it was very boggy, and replaced the DP 266 Atomiser for the DQ one. I haven't had chance to try out the changes made yet, just after people with far more knowledge of carb set ups than I have to give their opinions/advice.
Thanks in advance for any help/advice received.
hullygully wrote:Whats the jet above the pilot?
is it a CD1 or a B**?
Adam_Winstone wrote:FYI - Most people that I know to be running actually use the K needle range in their VHSH carbs. I did similar with my VHSA carb, which is also intended for U-needle use, and I've ridden a fair few TS1s set up with K-needles and they've all been excellent. Whilst the U needles are shorter than the Ks, with some dealers/tuners suggesting that you should cut Ks to U length, this has never actually added any benefit and everyone that I know is still running full length needles in their VHSH. Not in a TS1 but I have had one of the UK's most respected dyno operators dyno my VHSH with full length Ks.
Are you particularly set on using U needles (fewer options than the extended K range)?
PS - Having spent a lot of time using VHSH, VHSA and VHSB carbs, I have noted VERY different set-up suggestions from others, with main jets differing wildly (i.e. 135-175). Indeed, whilst AF's recommendations are often around the 165 mark, I know of plenty of people leaving dynos with mains around 140-145. Perhaps this is a reflection of your richness with your current main, and you might want to look at other needle and atomiser options. BTW - I would consider the price of a decent dyno session vs the rapidly mounting cost of buying VHSH components to try.
Good luck getting it sorted.
B1gD0gu3 wrote:I never even knew they existed, thank you very much for that! I will check them out.
B1gD0gu3 wrote:Have been in touch with them today, seems very knowledgeable and a genuine person. Am taking the scoot over to get it set up on the dyno. Will post results once i've got it sorted.
Thanks for the replies, appreciated & thank you Toddy for finding the place, 40minutes away & I didn't know it existed!
B1gD0gu3 wrote:Well it didn't go too well, made 15hp on the dyno, jetting was sorted but issues abound. Engine was opened up and multiple faults found wrt engine build. Had no go whatsoever. So a rebuild is in order to put right some of the problems found. Was more annoyed that my season is over before it has begun. If anyone is interested I will update once everything is rectified. Thanks for all the help, it's appreciated.
B1gD0gu3 wrote: Touring Torque Monster!![]()
Set up on Craigs dyno & it's making just under 27hp at 5712rpm and just shy of 26lbft at 5508rpm, with 20lbft available from 3600rpm.
shamrockexpress wrote:Sometimes it pays to shop local![]()
why did you change carbs back to phbh?
ULC Soulagent wrote:Feckin very expensive rebuild but glad ur sortedmyself have only used a dyno session twice in setting up carbs
1st one went bang around 146 miles after it. 2nd one using vhsh on my proddy scoot which went well over two seasons
