CHRIS in MARGATE wrote:Sounds like choke plunger stuck.
MickYork wrote:CHRIS in MARGATE wrote:Sounds like choke plunger stuck.
+1
Scooterdude wrote:Im just in the middle of one displaying exactly the same symptoms. Swapped carb over this morning for an identical one i have hear to rule that out.....exactly the same. Im thinking stator now, let you know later.
Scooterdude wrote:Scooterdude wrote:Im just in the middle of one displaying exactly the same symptoms. Swapped carb over this morning for an identical one i have hear to rule that out.....exactly the same. Im thinking stator now, let you know later.
Yes it turned out to be the stator so all fixed now.
Granty wrote:Scooterdude wrote:Scooterdude wrote:Im just in the middle of one displaying exactly the same symptoms. Swapped carb over this morning for an identical one i have hear to rule that out.....exactly the same. Im thinking stator now, let you know later.
mmm - The plot thickens, mine has done this with 2 x stators with the new BGM one only 12 months -- I thought for a second that could have been it but looked back through the timeline. Originally I thought it was just worn rings but I've renewed them also -- weird.
