VHSH needle and circlip wear
Postby Paul_from_Thornbury » Tue Jun 09, 2026 6:14 pm
I do love the VHSH but recently I’ve started to get excessive wear of the circlip and needle groove. It’s got to the point they barely last a few hundred kms.
I’ve seen info where people have used watchmakers circlips of much higher quality or using a half clip washer to try and isolate the vibration.
I’m wondering if my slide is excessively worn, causing the vibration. My float bowl is worn a little from cable rub. These two components alone are about €130. A whole new carb is only €230.
Any experience from other users or a better solution for the needle circlip?
Paul_from_Thornbury
Re: VHSH needle and circlip wear
Postby hullygully » Wed Jun 10, 2026 11:05 am
also check the plastic sleeve, if its a 34? that the slide fits in
Postby Adam_Winstone » Wed Jun 10, 2026 3:12 pm
All Dellorto needles wear and should be considered a replacement part, as necessary, but I have experience of VHSH needles not lasting as long as others.
If you've now fully established what is your correct needles clip position, could you not assemble with a tiny amount of silicone sealant on the clip and a short length lower? Providing the application is sparing then it could effectively rubber mount and secure the needle in position, limiting flutter and wear rate.
Return to Carburettors
Users browsing this forum: No registered users and 59 guests
