New member with his first Lambretta
Re: New member with his first Lambretta
Postby Kristof Lammy pie » Sun Oct 25, 2015 3:17 pm
Here are some pics of my lad the day we got it.
He insisted on the helmet!
Kristof Lammy pie
Postby Kristof Lammy pie » Wed Nov 25, 2015 8:21 pm
So after lots of work completed I took the TV for its Mot.
A bit gutted as it failed. :'(
Low reading on the front brake and front headlight too high.
Advisory on notchy steering.
Here it is at the Mot station
So I got home and tried adjusting the headlamp, easier said than done as it was as low as I could get it. So I've had to leave it a little loose so it will point down ish.
The front brake was my fault I avoided taking the front wheel and inboard disc apart for a service and new pads. It only read 90 on the meter. As opposed to a 200 reading on the rear.
So the front wheel is off and the hub is apart.
I've ordered some sintered pads from Scootopia.
Anyone have any advice on getting the best out of inboard disc?
Cheers Kris
Kristof Lammy pie
Postby Rich Oswald » Thu Nov 26, 2015 4:43 pm
Cheers Kris[/quote]
Reverse pull with sintered pads,
Postby Kristof Lammy pie » Thu Nov 26, 2015 7:31 pm
With reverse pull do I have to relocate the outer cable from the headset down?
Kristof Lammy pie
Postby Covboy » Thu Nov 26, 2015 10:06 pm
Hi kris
No you don't need to reroute the cable. Rimini do a full kit and I'm sure UK suppliers do too
I did the modification and was amazed at the difference it makes. Don't ask me why or how it works, it just does!
Also see stickys book
Postby Kristof Lammy pie » Sun Nov 29, 2015 11:12 am
Cheers.
Kris
Kristof Lammy pie
Postby dickie » Sun Nov 29, 2015 11:50 am
Covboy wrote:Hi kris
What he said. I did mine on a standard drum and I can now slow down and stop using my brakes rather than turning to religion.
http://www.ebay.co.uk/itm/Lambretta-Front-Brake-Reverse-Pull-Kit-/321920261592?_trksid=p2141725.m3641.l6368
you don't really need all these bits, but it makes it easier.
Postby Kristof Lammy pie » Wed Dec 02, 2015 7:39 pm
Thanks for the info guys.
I bought a reverse kit and fitted it, I'm pleased to say it passed the mot retest today.
So sending all the docs off tomorrow so it can be registered.
Hope haven't made any blinding errors.
Kris
Kristof Lammy pie
Postby Kristof Lammy pie » Tue Dec 15, 2015 1:37 pm
Well it's registered RCA 157B!!
It took about 8 days in total.;-)
Kristof Lammy pie
Postby dave411 » Tue Dec 15, 2015 2:17 pm
:D brilliant :D
dave411
Postby pauLI » Tue Dec 15, 2015 3:04 pm
Excellent
Now enjoy it
pauLI
Postby HxPaul » Tue Dec 15, 2015 4:04 pm
Kristof Lammy pie wrote:Well it's registered RCA 157B!!
Geat stuff.....................just in time for winter ;)
PS.Dont be tempted to ride it if there's any salt on the roads,it rots your alloy.
Postby Kristof Lammy pie » Tue Dec 15, 2015 6:44 pm
Thanks guys.
I've taken it apart and treated it to new cables, clubman 42mm exhaust and a Dellorto 25mm kit. :-D
Kristof Lammy pie
Postby STFC » Wed Dec 23, 2015 10:46 am
Kristof Lammy pie wrote:So after lots of work completed I took the TV for its Mot.
Cheers Kris
Are You Located close to Abingdon ? The M.o.t station looks very familair
STFC
Postby Kristof Lammy pie » Wed Dec 23, 2015 10:49 am
Yes I'm in Didcot. Mot station is Taylors (old Forge) at Drayton.
Are you local too?
Kristof Lammy pie
Postby STFC » Wed Dec 23, 2015 11:58 am
Kristof Lammy pie wrote:Yes I'm in Didcot. Mot station is Taylors (old Forge) at Drayton.
Are you local too?
Yes , Just outside Abingdon
STFC
Postby Kristof Lammy pie » Wed Dec 23, 2015 1:21 pm
Ok, what scooter have you got I will look out for you if I ever get mine finished. Kris
Kristof Lammy pie
Postby Kristof Lammy pie » Mon Dec 28, 2015 8:10 pm
So over the Xmas hols I've stripped the TV down and replaced all the cables. Fitted a new Scootopia Ancillotti exhaust and a new 25mm Dellorto phbl kit. It's all on and it starts first kick but just wondered about carb settings. Anyone got any advice?
Ta Kris
Kristof Lammy pie
Postby JETEX » Fri Jan 22, 2016 1:07 pm
Hi Kris. Have a look in the carb section on the Forum, plenty of advice on there about setting up your carb. Your Dad's Lammy had a HKA registration - which is from Liverpool. Did he live there, and do you know the rest of the registration number ?
JETEX
Postby Kristof Lammy pie » Fri Jan 22, 2016 9:17 pm
Hi.
Thanks for the reply.
Unfortunately I don't know the rest of the numberplate unfortunately. All I know is he bought it new from Horsmans in Liverpool in 62-63 ish. Had it a long time then sold it as he got a car. He was from Norris Green Liverpool
Kristof Lammy pie
