New project - winter model
Re: New project - winter model
Postby soullad » Fri Sep 18, 2015 11:58 am
Looks fun Dickie
If you fitting a new top end you might need to replace the original head cowling and therefore check clearance on your rear runners under the bridge piece. Also dry build your new floor runner strips as the holes may not line up too.
Keep the pics coming mate ...
soullad
Postby dickie » Fri Sep 18, 2015 12:33 pm
soullad wrote:Looks fun Dickie
It came without a head cowl so I need a new one, but I've decided to fit an Avanti head and cowl anyway. Will this cause issues with clearance?
Postby soullad » Sat Sep 19, 2015 1:42 pm
Probably but as with everything like this, a dry build will reveal all.
soullad
Postby dickie » Sat Sep 19, 2015 7:53 pm
Had a pleasant leisurely afternoon stripping the rest of the motor and repairing threads.
Just one little job to do now before I send it off to get modified for a ts1 barrel.
ImageDSC_0068_zpsg8poumhj by richardhenderson1968
This looks like it could be fun. :(
I'm not taking any chances with this so it's going into a bucket of diesel for at least a week.
Postby coaster » Sat Sep 19, 2015 9:07 pm
Sweet Jesus that doesn't look like it will be easy :shock: After the diesel use a blow torch and an impact driver, the type you belt with a hammer
Good luck
Postby Warkton Tornado No.1 » Sun Sep 20, 2015 3:01 pm
I don't think those screws will move, but if you have access to a pillar drill you can sometimes fit a long screw driver bit that is very snug & try & wind out the screws that way. If they don't shift, you are automatically centred to drill out incrementally (Ø 5 mm maximum to suit M6)
Postby dickie » Sun Sep 20, 2015 6:13 pm
I reckon you're right Mr warkton but I'm going to give it a go with the expectation that I'll fail.
Oddly (to me anyway), the screws have a philips head so that will help when I inevitably have to drill them out, as the drill tends to self-centre.
Anybody taking bets?
Postby dickie » Sat Oct 10, 2015 8:33 am
dickie wrote:I reckon you're right Mr warkton but I'm going to give it a go with the expectation that I'll fail.
I was right unfortunately. Soaked for a week or 2 in diesel, heated up (a lot) and then I used an impact driver which only served to wreck the heads.
So i invested in some 160mm long drills; 3mm, 3.5mm,4mm,4.5mm and 5mm. Amazingly, I didn't snap a single drill! Then I just tapped out what was left. It was actually very easy and when I do the spare engine I have under my bench I reckon I'll just go straight to the drills rather than farting about. It's in about the same condition as the engine I'm currently working on, so I can say with near certainty that they won't come out with a driver.
Postby Warkton Tornado No.1 » Sat Oct 10, 2015 12:54 pm
I bet you actually just 'cleaned up' the original M6 holes with a tap to get rid of any debris. Quite satisfying, in a way, ensuring some parts are not wrecked!
I hope you have good screws to use in place of the originals.
Postby dickie » Sat Oct 10, 2015 1:33 pm
Aye,you're right.That's what I meant.
I've a new challenge now which is to get the bearings etc out of the mag housing. This has been in diesel for the best part of a month but still doesn't want to play ball. Not a pretty sight is it?
ImageDSC_0082_zps7crjaqct by richardhenderson1968
I've got some really good circlip pliers and they simply couldn't shift it. So I manged to get the seal out from below the circlip, basically by destroying it. Then I used a small allen key (the largest one that would go through the hole in the circlip) and used it to lever against the mag housing inner face. This worked a treat, but I wish I'd taken a photo as it's a useful tip for someone else but I don't think I've explained it very clearly.
next I cleaned up the inner face as best I could to let the bearing slide out more easily. I heated it up (a lot) and tried to drift it out, but once again, it wasn't budging! Not having much luck,am I?
So I cobbled together a bearing puller from some parts of a silent block tool, then heated the whole lot before applying real force.
This worked, sort of............
ImageDSC_0086_zpsxlvsvli5 by richardhenderson1968
It has left half the bearing behind. I'm not sure how I'm going to get this out, so any suggetsions are welcome. I have a decent bearing puller with slide-hammer, but I doubt that's enough seeing as it has got a good enough grip on the bearing that it has allowed the outer race to yield.
Postby Captain Pugwash » Sat Oct 10, 2015 8:59 pm
Diamond burr will cut through what's left of the bearing, if you can cut it in two places it should fall out. Dremmel time 8-)
Captain Pugwash
Postby dickie » Sun Oct 11, 2015 7:48 am
Captain Pugwash wrote:Diamond burr will cut through what's left of the bearing, if you can cut it in two places it should fall out. Dremmel time 8-)
For some reason I see using the dremmel as admitting defeat (something probably happened in my childhood).
Regardless I did just as you said: I cut through in 2 diametrically opposite places. Not all the way through as I was trying to avoid damaging the machined face. Once it was really thin I gave it a whack with a cold chisel and it pretty much dropped out.
This has been the least glamorous engine strip in the history of mankind. But I enjoy a challenge and it's over now. :D
I've now got to get the cases off to oiltek to be modified for a ts1 barrel and vapour blasted.
Postby 911hillclimber » Mon Oct 12, 2015 7:47 am
What a bitch!
10/10 for perseverance, great job done.
I too see the dremmel approach as not quite right, but there are times....
Good progress!
911hillclimber
Postby dickie » Mon Oct 19, 2015 10:16 am
I've been getting parts together for the engine rebuild. I plan to use a SIL GP crank with a Yamaha rod, so I bought this 'genuine' SIL crank, which I will not be using. Look at the bearing surface!
ImageDSC_0092_zps0eezdfau by richardhenderson1968
Postby dickie » Fri Dec 18, 2015 2:59 pm
Got my casings back from Oiltek today.
ImageDSCF0276_zpsozubwqbb by richardhenderson1968, on Flickr
If you look closely you can see a number of voids in the aluminium welding; harmless.
ImageDSCF0284_zpszygdvtzm by richardhenderson1968, on Flickr
ImageDSCF0290_zpskiwnqtoh by richardhenderson1968, on Flickr
Still haven't decided what pipe to use but I've got the extra mount on anyway so if I use a clubman the option's there for me.
ImageDSCF0279_zpseavi2cpi by richardhenderson1968
The recess for the kickstart rubber was missing a large chunk but they've done a good job of repairing it.
ImageDSCF0277_zpsna3y3lfs by richardhenderson1968
If you look back earlier in this thread you'll see the state of the bottom end. It obvisouy had water in for a number of years and oxidised the mag flange and crank case. When it was vapour blasted that aluminium oxide came off leaving these pock marks behind, but I don't see how they'll cause any harm other than being ugly so I'll just use this as I don't want to replace anything I don't have to.
ImageDSCF0286_zps60upyxry by richardhenderson1968, on Flickr
Same thing in the crank case but not as bad as the mag flange.
ImageDSCF0287_zps1rbclxy0 by richardhenderson1968, on Flickr
Postby Warkton Tornado No.1 » Fri Dec 18, 2015 7:44 pm
Those Moon craters that are in the 'bottom end' & magneto housing are not going to harm anything. It depends on whether you subscribe to the theory of crankcase compression being best when it is 'high' or 'low' which, in turn, may be influenced by your choice of exhaust.
Personally, I'd be inclined to dress them a bit as an excuse to lower crankcase compression, especially if you are 'stroking' the crankshaft up to 60 mm or more. That's if you've changed your plans since you showed the dodgy SIL crank bearing journal!
However, I'm intrigued as to the 'step' in the crankcase around the four stud holes & transfers. Have you welded in a packer of some sort, or have I still got double vision?
Excellent work, by the way, as to the weld of the kickstart butt plug hole & the overall finish.
Postby dickie » Sat Dec 19, 2015 10:25 am
Warkton Tornado No.1 wrote:Those Moon craters that are in the 'bottom end' & magneto housing are not going to harm anything. It depends on whether you subscribe to the theory of crankcase compression being best when it is 'high' or 'low' which, in turn, may be influenced by your choice of exhaust.
While I understand the basis of each theory, I don't know enough about it to have any worthwhile point of view, so I just ignore it.
Warkton Tornado No.1 wrote:Personally, I'd be inclined to dress them a bit as an excuse to lower crankcase compression, especially if you are 'stroking' the crankshaft up to 60 mm or more. That's if you've changed your plans since you showed the dodgy SIL crank bearing journal!
That dodgy crank wasn't dodgy at all. It was just a machining rag which unusually hadn't blued so looked like it was really part of the crank. I thought I'd try dressing it with a needle file and it just fell off leaving a perfectly decent crank behind.
Warkton Tornado No.1 wrote:However, I'm intrigued as to the 'step' in the crankcase around the four stud holes & transfers. Have you welded in a packer of some sort, or have I still got double vision?
No, it's just that he machines back the first few mm of weld to the factory profile. But you've now got me wondering if I should have got him to leave 3mm extra height as I'm using a 110mm rod
Warkton Tornado No.1 wrote:Excellent work, by the way, as to the weld of the kickstart butt plug hole & the overall finish.
I don't think it's actually a butt plug, but they do work well in that application. :o
Postby Warkton Tornado No.1 » Sat Dec 19, 2015 12:17 pm
Ha Ha! I'm glad you took my comments in the spirit they were meant.
From what I understand, & I'm probably getting this wrong, the extensive welding has been cut back by a machining process that has replicated the original external process extremely well.
I think you've done something like that......
Wow! Presuming the welding hasn't caused distortion, there must be so many crankcases up & down the country (Ahem!) that are 'fragile' ex-racing blocks ported to the maximum & would benefit from that process if it were available & affordable.
What you say about longer rod begs comment, & it also crosses over to primary compression.
Many years ago, before a certain famous tuner broke cover with his radical ideas applied to his own race bike, I had cranks rebuilt with his suggestion of rods intended for a Japanese motorbike. They were 105 mm centres. As ever, with me, this was all about a Group Four Lambretta.
Our 'seat of the pants' dynos all agreed power & it's delivery were better.
However, what I brought to the table was my internal Motoplat that Ray Kemp sold me having rejected it after his trials. He in turn was using it as the result of Terry Shepherd (RIP) advocating it's use. This rapidly advanced from Zero up to about four/five thousand then retarded to about 10 degrees retarded @ ten thousand. It was a culture shock & took some understanding & set up, but the perseverence & belief in it was mine alone.
The drive from the bike was incredible. The punch out of the hairpin on Cadwell's club circuit was fantastic. Far better riders than me would comment upon how they'd chase me down, only to be left in my wake from the hairpin.
But I couldn't bring that engine home in first place.
Now, I know why.
Too high a primary compression that was brilliant @ pumping low down for immense torque (for it's day!) but caused a massive load once the motor was spinning!
After chasing my tail for years, I now use only long rods & do my best to lower primary compression on a race bike & road bike. If the opportunity presents itself, a longer stroke should be applied to the mix as well.......
I hope this insight helps you with your decision making.
Just don't forget the lube when it comes to fitting that kickstart butt plug & it's replacement. Aaah! Lambrettas are so Italian female.
Postby dickie » Sat Dec 19, 2015 3:44 pm
Warkton Tornado No.1 wrote:From what I understand, & I'm probably getting this wrong, the extensive welding has been cut back by a machining process that has replicated the original external process extremely well.
Wow! Presuming the welding hasn't caused distortion, there must be so many crankcases up & down the country (Ahem!) that are 'fragile' ex-racing blocks ported to the maximum & would benefit from that process if it were available & affordable..
It does cause some distortion which meant that the mag gasket face had to be machined a little. A thicker gasket is enough to take up the small difference.
Also, this process is readily available. I had mine done by oiltek but mike phoenix and possibly others offer the same service.
Whether it's affordable or not is of course subjective but mine cost £266 but that included blasting, additional repair work and some minor parts. Delivery was included too.
And thanks for the bit of education regarding crankcase compression.
Postby Warkton Tornado No.1 » Sat Dec 19, 2015 5:24 pm
Dickie.
Thank you for the information & your kind words.
Good Luck with the rest of the project!
