by davla » Thu Apr 12, 2018 11:55 pm
Is there any reason why I can’t use Li brake shoes on a GP front hub back plate?
davla
by HxPaul » Fri Apr 13, 2018 9:25 am
I use Makino (Indian) on an Italian Li,so I dont see any reason why not.
by Adam_Winstone » Fri Apr 13, 2018 2:36 pm
LI and SX cam is a different thickness, with shoes differing to suit. If you want to interchange then you need to swap out the cam too.
by davla » Fri Apr 13, 2018 2:56 pm
Cheers for the replies, I should be ok then as I'm just transferring all of the moving parts from and early 'weak' backplate to a GP backplate. I'd dry assembled it before dropping off to the powder coaters and it all seemed fine but just thought I'd check in case I'd missed something.
davla
by St George » Fri Apr 13, 2018 5:37 pm
I think the SIL GP 200 take LI Shoes from memory, I bought some a couple of years ago from an established dealer.
St George
by Scooterlam » Wed Apr 18, 2018 9:46 pm
I'm sure I've had universal shoes that came with a clip on shim so usable with both cams.
Scooterlam
