Pacemaker box combo
Pacemaker box combo
Postby steveg » Wed Oct 11, 2017 5:02 pm
I have a Pacemaker gear set with the early hollow cluster and the later 3rd gear cog.
Can these be used together? I'm guessing not.
steveg
Re: Pacemaker box combo
Postby Warkton Tornado No.1 » Wed Oct 11, 2017 6:09 pm
I use a hollow cluster in a Rapido 245 which pulls 19 x 46 (same as TV200, so quite grunty) with a third with the stronger teeth (33.8 mm across five teeth)
Postby AlG » Wed Oct 11, 2017 6:15 pm
I have used both, and had a late cluster centre drilled to take a pressure plate with the central locating pin. Always the strong 3rd and typically run 18x47 for 4.8 final drive.
AlG
Postby Warkton Tornado No.1 » Wed Oct 11, 2017 6:28 pm
AlG wrote:I have used both, and had a late cluster centre drilled to take a pressure plate with the central locating pin. Always the strong 3rd and typically run 18x47 for 4.8 final drive.
Bl**dy Hell, when I tried to get clusters drilled & reamed @ the machine shop where I worked, they said their tooling wouldn't touch the hard material! Or were they just trying to get out of doing a bit of 'Guvvo' for me (standard cost: one cup of dispensing machine coffee) :lol:
I agree with you as the hollow centre type was the best configuration Innocenti ever did.
(As clutches have improved & the trend for higher gear ratios continues, I predict that the TV200 'box is going to make a comeback as a change to the LI150 which has been prized of late....)
Postby steveg » Wed Oct 11, 2017 6:37 pm
Warkton Tornado No.1 wrote:I use a hollow cluster in a Rapido 245 which pulls 19 x 46 (same as TV200, so quite grunty) with a third with the stronger teeth (33.8 mm across five teeth)
That's good news then :D
steveg
Postby AlG » Wed Oct 11, 2017 6:50 pm
The guy who centre drilled the cluster was an old school engineer who spend most of his time machining and balancing parts for classic TT bike engines. Was a sad day for scooterists in Swindon when he retired.
AlG
