front hub tight
front hub tight
Postby mr mugello » Wed Feb 15, 2017 11:16 pm
Just replaced the two front hub oil seals. Hub was spinning freely on the spindle like a roulette wheel before I split for painting. Would the fitment of new seals cause tightness on the hub spindle ? Thanks
mr mugello
Re: front hub tight
Postby Warkton Tornado No.1 » Wed Feb 15, 2017 11:58 pm
mr mugello wrote:Just replaced the two front hub oil seals. Hub was spinning freely on the spindle like a roulette wheel before I split for painting. Would the fitment of new seals cause tightness on the hub spindle ? Thanks
If that is the only change, then 'Yes'
They seal by rubbing & must never be fitted 'dry' as they rely entirely upon lubrication to run in & hence do the sealing of the hub contents (grease)
You could try copious amounts of penetrating oil (or GT85) to increase the lubricity in the area of the lips which would do no harm.
Re: front hub tight
Postby mr mugello » Thu Feb 16, 2017 12:35 am
Just thinking back. The seals don't come in contact with the spindle, metal spacers fitted in the centres. Fresh grease packed around bearings might be simply causing problem of stiffness.
mr mugello
Re: front hub tight
Postby Warkton Tornado No.1 » Thu Feb 16, 2017 2:55 am
mr mugello wrote:Just thinking back. The seals don't come in contact with the spindle, metal spacers fitted in the centres. Fresh grease packed around bearings might be simply causing problem of stiffness.
The seals rub on collars (or top-hat collars) as you say, but they will still make the wheel stiff to turn, regardless of not rubbing on the actual spindle. The collars do no turn as they are fixed with the spindle, whereas the seals rotate with the hub.
Re: front hub tight
Postby mr mugello » Thu Feb 16, 2017 8:41 am
Yes sorry. I realise the top hat outside collar is clamped up with spindle. Is it also possible you can punch the inside seal in too much which will push the bearing in further causing it to rub pressure on the long central spacer ?
mr mugello
Re: front hub tight
Postby Warkton Tornado No.1 » Thu Feb 16, 2017 3:27 pm
mr mugello wrote:Yes sorry. I realise the top hat outside collar is clamped up with spindle. Is it also possible you can punch the inside seal in too much which will push the bearing in further causing it to rub pressure on the long central spacer ?
You shouldn't be able to as there are abutment faces to which the seals are fitted up to.
Time for a hub strip, I reckon, presuming it's not the speedo drive ;)
Re: front hub tight
Postby Wack » Thu Feb 16, 2017 6:36 pm
If you've just had the hub painted, check the backplate isn't rubbing in the rebate on the hub. Try slackening the inner axle nuts and see if the hub spins free.
Re: front hub tight
Postby mr mugello » Fri Feb 17, 2017 12:14 am
Will give it a try. Thanks.
mr mugello
