Greasing Series 2 Fork Links - How?
Postby 507VBH » Mon Jan 09, 2017 5:58 pm
Hi,
The instruction booklet for my Series 2 says that the fork links should be greased every 2500 miles :) As it's been off the road for decades, I guess they may need some grease. However there is no grease nipple on the fork link pivot bolts. There is a grease nipple on the bottom of the links though. Is it possible to remove the fork link bolts and push some grease into the bush without the whole link + spring assembly falling apart?
Cheers!
507VBH
Re: Greasing Series 2 Fork Links - How?
Postby HxPaul » Mon Jan 09, 2017 6:22 pm
507VBH wrote:Hi,
Cheers!
The earlier ones had grease nipples on the end of the link bolts,if yours dont the only way is to remove the bolts and grease them and re-fit them.If they've been on for that long the chances are that you will need new bushes and to be safe replace the link bolts.
Postby Tractorman » Mon Jan 09, 2017 7:07 pm
If it has not been used for that long a full strip down would be a very good idea.
Postby 507VBH » Mon Jan 09, 2017 9:48 pm
Thanks for the comments. What diameter are the bolts?
507VBH
Postby 507VBH » Mon Jan 09, 2017 10:14 pm
507VBH
Postby Steve J » Tue Jan 10, 2017 12:16 pm
Not sure, but SR stock them. They also sell the earlier type for Series 1 & early Series 2 forks, with the internal drilled passageway and grease nipple. To get the benefit of being able to grease the things, you would also need to drill a small hole through the steel pivot bush, and ideally fit the bronze bush in the links.
Apparently, the nylon bushes were designed to be 'self lubricating' - which generally meant no grease was ever applied, and they seized solid onto the pivots within a few years. At that stage, a blowtorch to melt them out might be the best option.....
Steve J
