Engine Cowling Removal
Postby ROClarke » Fri Dec 16, 2016 9:07 pm
Hi
I have just got back into scooters after a life away and cannot wait to get my hands dirty.
I have purchased a very nice DL200 with a TSL 225 barrel.
The question is can I remove the cylinder cowling without removing the engine or undoing rear shocker ?
ROClarke
Re: Engine Cowling Removal
Postby byron » Fri Dec 16, 2016 9:24 pm
no.
you'll need to remove the rear shock, and taking out the bumpstop will allow the front of the engine to drop down further.
then, depending upon what sort of pipe you have, you may have to remove the header to actually get the cowling off... but if you do have to do that, cut the cowling to enable fitting / removal without disturbing the header pipe next time...
byron
Postby Knowledge » Fri Dec 16, 2016 9:24 pm
It depends on your exhaust, but you will have to remove the rear shock. It's easy.
Postby Phil D » Fri Dec 16, 2016 10:19 pm
Welcome to poverty! :lol:
Phil D
Postby ROClarke » Sat Dec 17, 2016 8:11 pm
Phil D wrote:Welcome to poverty! :lol:
Been poor for years !
ROClarke
Postby Phil D » Sat Dec 17, 2016 8:26 pm
Me too .
Started out with nothing and I've got most of it left. :lol: :lol: :lol:
Phil D
Postby Knowledge » Sun Dec 18, 2016 8:59 am
Why do you wish to remove the cowling?
Postby ROClarke » Sun Dec 18, 2016 10:45 pm
Knowledge wrote:Why do you wish to remove the cowling?
I want to paint it.
ROClarke
Postby Knowledge » Sun Dec 18, 2016 11:30 pm
Oh. That was a bit disappointing. Still, it's a proper reason.
Postby EddieStone » Mon Dec 19, 2016 12:15 pm
On mine I sort of have to undo the cowl and the exhaust at the same time, once the rear shock has been removed.
And that's how it goes back together. Pain in the rear, for sure.
EddieStone
