scootRS Tubeless Rims leaking Air
Postby drivera » Sat Jul 02, 2016 2:40 pm
Had 2 Dunlop scootsmart tyres fitted to some scootRS tubeless rims yesterday , I used the bolt in valves supplied and the buggers are leaking air around the rubber valve seats , had a word with the tyre fitter who suggested filling the tyre with green gunk ???
Seems a sh*t idea , but as the tyres are a pig to get off the rim any idea what I can do ??
drivera
Re: scootRS Tubeless Rims leaking Air
Postby col68 » Sat Jul 02, 2016 4:57 pm
Hi mate just had same problem with mine took them to bush tyres and had them removed and new pull in type put in cost me £11 for 3 wheels . col
col68
Postby drivera » Sat Jul 02, 2016 5:59 pm
Cheers Col , I'll give em a try in the week :)
drivera
Postby rossclark » Sat Jul 09, 2016 10:30 pm
I have a couple of ScootRS wheels that I fitted Bridgeport valves to. They're bolt in type and you need to remove a small portion of the rim above the valve hole and ensure the area where the valve sits is flat (file it) but they've not leaked at all.
