Donnie wrote:Aha! so thats all the 3rd pin does then! Im definitely fitting a buzzer, would that wire to the 3rd pin I wonder?
And do I need an idiot light for the mot?
Digger wrote:Donnie wrote:Aha! so thats all the 3rd pin does then! Im definitely fitting a buzzer, would that wire to the 3rd pin I wonder?
As indicators weren't a requirement when it was first registered you can tape them up for the MOT.
You'll need a friggin loud buzzer!!!!!!!!!!!!!!!!!!!!!
peejay wrote:will 3 watt festoons be bright enough?
why do you not want to use leds then, i'm curious.
Shaun wrote:If it was a car, an 'audible warning' would be allowed, but its not, so a 'tell tale' must be fitted, or the indicators fitted so they are visible from the riding position.
Then we have Diggers option of tape, which is also perfectly acceceptable
Donnie wrote:peejay wrote:will 3 watt festoons be bright enough?
Yep, will be more than bright enough as im running a wassell and battery. Already done a quick test or the lights im using and they're quite good.
MK Monty wrote:The 3 pin flashers tend to use the 3rd pin. My ace well had idiot lights for left and right. The single led was a bit more challenging and needed to take a feed from both sides but using a diode to stop the flow going the wrong way and lighting the other side. Look at a diode as a one way valve lets the flow through to the led warning light but not back to the other side or set of lights. You will need 2
Users browsing this forum: Google [Bot] and 211 guests
