Lighter/ Easier Clutch Solutions for Hand injury
Postby scarkey » Tue Jan 09, 2024 6:59 pm
Hi,
I am currently recovering from a broken left hand, grip is not so good.
I am looking at solutions to make the use of the clutch easier eg AF Rayspeed Easy Clutch etc.
What have others used as a answer to this problem
TIA
Clarkie
York SC
scarkey
Re: Lighter/ Easier Clutch Solutions for Hand injury
Postby Storkfoot » Tue Jan 09, 2024 9:57 pm
I can vouch for this Chiselspeed conversion. I have it on an LTH 7 plate and the clutch is as soft as on my standard TV175. It’s not cheap but it works.
https://www.chiselspeed.co.uk/store/product/CST845465B
I tried the AF easy clutch but gave up. It made the difference between a slipping clutch and a dragging clutch to be almost non existent. I could probably have persisted with every available permutation but I lost patience and took it off.
Postby Tractorman » Wed Jan 10, 2024 10:18 am
I have a LTH 7 plate clutch in the sidecar engine and Martin at Chiselspeed recommended using standard springs in the clutch when I mention the clutch was stiff to use. I did so and it is much easier and up to now as worked fine.
Postby Norrie Bodge » Wed Jan 10, 2024 3:39 pm
AFs UNI easy-clutch
Paired with the AF cassette
Works well on TS-230
Norrie Bodge
Postby Rich Oswald » Wed Jan 10, 2024 7:53 pm
Storkfoot wrote:I can vouch for this Chiselspeed conversion. I have it on an LTH 7 plate and the clutch is as soft as on my standard TV175. It’s not cheap but it works.
I've tried both and the Chiselspeed was by far the best option. The dearest but the best. That's not to say that the AF didn't work because it did. I tried the AF on a st'd clutch with MB springs at first, this was despite most people saying it doesn't work with st'd clutches but it did help. I then tried it with an AF Road cassette which was an improvement again but still not as good as the Chiselspeed.
Postby Cgt75b » Sun Jan 21, 2024 9:52 am
scarkey wrote:Hi,
TIA
Clarkie
York SC
Have you tried Derek Dowlings easy clutch?
Postby Toot » Sun Jan 21, 2024 10:56 am
I'd definitely recommend this option, arguably one of the most practical conversions available for a Lambretta engine. Especially anyone (like me) now suffering with aching hands/fingers from many years of winter riding when I was younger.
I fitted my conversion before riding to the Euro in Poland and it made the journey an absolute pleasure. I'll definitely get this done for any other 'performance' engines with an up rated clutch. (I have an AF Race Clutch in my TS1). I can pull in the clutch lever with one finger now.
Toot
Postby Den08 » Sun Jan 21, 2024 12:42 pm
After two Brocken fingers and wrist screws plate etc thought that’s it for me.
Rb250 Af uni easy clutch with Lth clutch new sip clutch cable, two finger clutch now absolutely
Spot on, best of luck for your recovery.
Den08
Postby Storkfoot » Sun Jan 21, 2024 1:18 pm
Den08 wrote:After two Brocken fingers and wrist screws plate etc thought that’s it for me.
On the AF Easi Clutch, what notch did you use for the clutch cable trunnion?
Postby trotsky » Sun Jan 21, 2024 2:22 pm
Cgt75b wrote:
scarkey wrote:Hi,
TIA
Clarkie
York SC
Agreed. Would definately recommend. Just put one on Wendy's TS1....superb bit of kit. ;)
trotsky
Postby Den08 » Sun Jan 21, 2024 4:12 pm
Tbh i used the original clutch arm, the uni arm didn’t sit to well on the uni spline’s sod the fetling as
as it is all interchangeable it’s only the rack and pinion that makes the difference anyway and it does it really well.
Den08
Postby Rich Oswald » Mon Jan 22, 2024 11:52 am
trotsky wrote:
Cgt75b wrote:
scarkey wrote:Hi,
TIA
Clarkie
York SC
Hi Steve, I've heard a lot of negative feedback about these. Some say it reduces the adjustment between Clutch slip and Clutch drag massively and they have taken them off.
Postby Rich Oswald » Mon Jan 22, 2024 11:54 am
Paul, I used the notch nearest the tyre, so in theory I could go back to the st'd Innocenti clutch arm also.
Postby Storkfoot » Mon Jan 22, 2024 6:16 pm
I did the same too, Rich. Anyway, I no longer have the Easi Clutch. I was just curious as to whether it was set to one of the notches nearer the pivot of the lever.
Postby trotsky » Mon Jan 22, 2024 9:07 pm
Hi Rich,
Strange? We tried the AF set up & i couldn't get to work at all, but with Derek's Mk4 version no probs, i measured it before & after & it has the same cable travel with the same clutch & dogleg lever, just a quite noticeable lighter feel at the lever?
Weeksey has one on, which seem's to work great, so that's what prompted us to try one on Wendys... tho not rallied it yet for a proper testing, so far so good. :?:
trotsky
Postby Rich Oswald » Tue Jan 23, 2024 11:40 am
trotsky wrote:Hi Rich,
Steve, i'm not knocking it as i've not tried one but just going on what's been reported.
Postby scarkey » Tue Jan 23, 2024 4:08 pm
Thanks to all who replied to this Post.
Plenty to think about while trying to build the grip in my hand back.
Best Wishes
Steve "Clarkie" Clark
York SC
scarkey
Postby alex_hughes » Tue Jan 23, 2024 4:55 pm
I highly recommend the Chiselspeed conversion. Expensive but I’d say worth every penny.
alex_hughes
Postby L111amo » Tue Jan 23, 2024 6:20 pm
I tried the earlier versions & couldn’t get them to work, seen the latest version, different take on it, any experts that think it work any better ?
L111amo
Postby Rich Oswald » Wed Jan 24, 2024 11:25 am
L111amo wrote:I tried the earlier versions & couldn’t get them to work, seen the latest version, different take on it, any experts that think it work any better ?
I take it, this is Derek Dowling's mechanism?
