OEM innocenti one
the unmarked one
The width of the OEM on the legs is about 6.5mm and 7mm on the other, thanks Paul
Warkton Tornado No.1 wrote:Ha! Looks like just you & me interested in this topic then......
dickie wrote:You'll struggle against them with needle files i think. They are very hard.
Fast n Furious wrote:Did you check your driven shaft endfloat measurement before stripping it? This can also cause gears to jump if out of tolerance.
