UNI side casings
UNI side casings
Postby Storkfoot » Sun Jan 03, 2021 10:04 pm
I used one earlier this year and was impressed with the finish, with one exception. I had issues getting the kick start shaft through the bush. I tried another shaft with the same issue. I resolved the issue with a lot of effort with wet and dry paper.
The reason I mention this is that I am after another GP side casing. Has anyone else had any similar issues?
Re: UNI side casings
Postby Fast n Furious » Sun Jan 03, 2021 11:33 pm
I can't remember ever fitting new bushes and shaft without having to ream the bushes to get the required 'tight as practicaly possible' clearance.
The action of pressing these 2 thin, interference fit, brass bushes into the ally casing results in a small amount of "out of round distortion" of the bushes. So, reaming to size, is just a standard procedure here.
The new UNI casing is unlikely to have any bearing on it.
Postby Storkfoot » Mon Jan 04, 2021 2:51 pm
Good point. I have just never had to do it before.
Postby ROClarke » Sat Jan 09, 2021 11:59 am
Storkfoot wrote:Good point. I have just never had to do it before.
Better to be really right or the outside bush has a habit of drifting back along the kickstart shaft and will result in the shaft moving around as the bush will sit in the space between the 2 bushes which is not ground but cast and is a smaller diameter than the shaft bush faces.
ROClarke
Postby ROClarke » Sat Jan 09, 2021 12:01 pm
Sorry should read “really tight” and not “really right”
ROClarke
Postby dickie » Sat Jan 09, 2021 3:31 pm
Storkfoot wrote:I used one earlier this year and was impressed with the finish, with one exception. I had issues getting the kick start shaft through the bush. I tried another shaft with the same issue. I resolved the issue with a lot of effort with wet and dry paper.
I've recently fitted 2 x UNI side casings. One had the old used kickstarter from the engine being repaired. The other had a brand new MB one. Both assembled easily without any reaming required.
Postby Storkfoot » Sat Jan 09, 2021 6:49 pm
Thanks for the replies. I have ordered another UNI sidecasing.
Postby Storkfoot » Wed Jan 13, 2021 6:41 pm
Storkfoot wrote:Thanks for the replies. I have ordered another UNI sidecasing.
I have received the sidecasing and I have the same issue again.
The bushes are approximately 22cms and 25cms. Is anyone able to recommend a reamer (set or adjustable) that doesn’t cost an arm and a leg please?
Failing that, I shall take it to a local engineering business.
Postby coaster » Wed Jan 13, 2021 11:37 pm
What you could do with is a small flap wheel just slightly wider than the bush, they are available for dremels but not sure if right size. Only suggesting as it isnt a critical bush as such ;)
Postby Storkfoot » Thu Jan 14, 2021 10:26 am
coaster wrote:What you could do with is a small flap wheel just slightly wider than the bush, they are available for dremels but not sure if right size. Only suggesting as it isnt a critical bush as such ;)
Good idea. I’ll get some new ones and give it a go. I did try with some old ones last time but found wet n dry was more successful even if it was for hour after hour.
Postby Warkton Tornado No.1 » Thu Jan 14, 2021 5:48 pm
Your best course of action might be to let the man @ the top know about this issue. There might be any number of ways to contact him, but a very 'transparent' method is via:
https://in.linkedin.com/in/manish-mittal-51167520
which I believe anybody can join.
It's only fair to give the guy a chance to get things right..... ;)
Postby Storkfoot » Thu Jan 14, 2021 7:22 pm
I reckon I need to shed 0.49mm off one bush, 1.28mm off the other. That is quite a lot for a flap wheel.
That is when compared to a shaft that works perfectly well in a SIL sidecasing. Disappointing.
I am not going down the route of going on Linked In but I am going to feed it back to AF (I bought one of my two UNI casings from them) who are, I believe, the main importers of UNI products.
Postby Fast n Furious » Thu Jan 14, 2021 11:39 pm
A pair of adjustable reamers new £22.50 delivered. One is typically 21.4mm - 23.8mm and the other is 23.8mm - 27.00mm. A bargain investment me thinks. ;)
PM me for details.
Postby Storkfoot » Fri Jan 15, 2021 12:40 am
PM me for details.
Thanks for your help. Order placed.
Users browsing this forum: No registered users and 175 guests
