I'm part way through rebuilding a lambretta, and I've lost the wiring diagram that was supplied with my electronic kit (almost 30 years ago!) Does anyone have a copy of the DC diagram? I can only find the AC diagram online.
Cheers, Steve
johnnyfartpants wrote:Does the regulator not need to be earthed then? Most regulators seem to have a terminal marked with a ground symbol.
My regulator that came with the kit is marked 343152 with terminals marked G G R B+ C ( R and B+ terminals joined together)
From the diagram in Sticky's manual, my regulator has its terminals in a different position - obviously the battery must go to B+ but where does the brown wire go to (R or C)
In case nobody had noticed, electrical stuff is not my best subject!
martyn dwane wrote:I'm part way through rebuilding a lambretta, and I've lost the wiring diagram that was supplied with my electronic kit (almost 30 years ago!) Does anyone have a copy of the DC diagram? I can only find the AC diagram online.![]()
Cheers, Steve
martyn dwane wrote:hope it helps.
martyn dwane wrote:i seem to remember , my battery used to go flat after a few days if i didn`t use it, even with the switch fitted from Reg to junction box, but it was along time and ive been asleep since then![]()
Users browsing this forum: No registered users and 189 guests
