SIP speedo on Series 1 with hydrulic hose.
Postby HartleyHare » Fri Nov 23, 2018 6:15 pm
Help needed please. I'm trying to fit a SIP speedo on a S1. I've got a hydrulic hose running down into horncover on throttle side. I can't see any space now to get the extension cable up from power box into speedo body. Extension cable has a fairly big connector on end. Then there's the temp sensor cable too ...... anybody done this? Cheers.
HartleyHare
Re: SIP speedo on Series 1 with hydrulic hose.
Postby Toddy » Sat Nov 24, 2018 8:54 am
I swapped the standard nut from the headset clamp for a smaller nylock type this allows you more space to feed cables /wiring down the gap , I run my thumb choke cable through there
Postby HartleyHare » Sat Nov 24, 2018 2:07 pm
Thanks for reply Toddy. Yes good solution this also allows hydrulic hose though bolt hole on headset bottom. No need to drill headset now. Cheers Harvey
HartleyHare
