Scooterdude wrote:Have you forgot to put the shim under the gear cluster i wonder resulting in the 4th gear rubbing on the casing, easily done.
HxPaul wrote:In my PM to you on the 22nd June I suggested that it could be the selector curser catching on first or second gear,I also suggested that you might have a gear in the wrong way around.Seeing as you are stripping the gearbox to have a look,you might pay special attention to these areas.
dscscotty wrote:Check the end plate studs are not to long and rubbing on chain?
Users browsing this forum: No registered users and 107 guests
