Recognise this noise - NOW WITH VIDEO AND SOUND (page 3)
Re: Recognise this noise - NOW WITH VIDEO AND SOUND (page 3)
Postby Scooterdude » Mon Jul 16, 2018 4:58 pm
Have you forgot to put the shim under the gear cluster i wonder resulting in the 4th gear rubbing on the casing, easily done.
Scooterdude
Postby harps2 » Mon Jul 16, 2018 8:38 pm
Scooterdude wrote:Have you forgot to put the shim under the gear cluster i wonder resulting in the 4th gear rubbing on the casing, easily done.
Nope sorry - new shim in place
harps2
Postby harps2 » Mon Jul 16, 2018 8:40 pm
HxPaul wrote:In my PM to you on the 22nd June I suggested that it could be the selector curser catching on first or second gear,I also suggested that you might have a gear in the wrong way around.Seeing as you are stripping the gearbox to have a look,you might pay special attention to these areas.
Checked for selector catching as per stickys book - No evidence, and gears all correct way round again as per stickys - cheers
harps2
Postby dscscotty » Mon Jul 16, 2018 8:49 pm
Check the end plate studs are not to long and rubbing on chain?
Postby harps2 » Mon Jul 16, 2018 10:46 pm
dscscotty wrote:Check the end plate studs are not to long and rubbing on chain?
Checked and OK not rubbing
harps2
Postby Scooterlam » Mon Jul 23, 2018 3:41 pm
hopefully this solved mine Cheers.
Scooterlam
Postby Danbretta » Sun Aug 12, 2018 6:23 pm
Just wondering, did you ever get to find out what was causing your engine issue?
Danbretta
Postby kennystag » Thu Aug 16, 2018 12:48 pm
Any news
kennystag
Postby sunrisemac » Thu Aug 16, 2018 7:40 pm
Interested to hear the outcome, still sounds to me like a tightly meshed gear as the noise is not constant but seems to go in 'waves'.
Hope you got it sorted whatever it was.
sunrisemac
Postby Danbretta » Fri Aug 24, 2018 7:05 am
Anything??? I'm in the process of rebuilding my gearbox and would be handy to know what your issue was in case I build it into mine..
Danbretta
Postby kennystag » Sun Sep 09, 2018 8:24 am
Hi harps 2,
Any news in sorting out your noise, please keep us posted.
kennystag
Postby harps2 » Wed Sep 12, 2018 9:50 am
hi sorry for long absence - been away 0n holidays - basically stripped right down again (inc RR wheel) clutch out, gears out selectors etc etc - rebuilt and re- shimmed and everything is fine - I think the rear wheel may have not been tightened up to correct torque which in turn was effecting all clearances.
Thanks for all your advice - could not have done it without you !
harps2
Users browsing this forum: No registered users and 61 guests
