Eden wrote:Bilko is the kickstart shaft broken?
CHRIS in MARGATE wrote:I wonder if others think like myself?
Are there any assumptions being made with regard to the three necessary requirements?
Fuel, ignition, compression.
Fresh fuel, different carbs, fuel tap and breather.
No fuel filters fitted?
Worth a shot of Bradex Easy Start.
Ignition? Plug gapped; with correct feelers, plug cap, HT lead, swapped CDI and stator and flywheel. Woodruff key intact.
Have you measured frame earth to engine earth... Should be 0 ohms.
Consider isolating all junction and terminal boxes and connecting wiring straight through in case anything leaking to earth.
Compression: Different top end tried so gaskets new and no leaks.
You say the oil seals are OK but how have you established their integrity?
Aside from a crack taking in air in the bottom of the crankcase I would say one or more of the replaced/substituted components is faulty.
Trust me, I'm not criticising but I think there is something very basic missing here when you examine ....Fuel, Ignition, Compression. I wish I lived nearby !
Scooterlam wrote:S
me as chris,
theres a great bit in Zen and the art of motorcycle maintenece, although written many years ago it could well be describing
This very thread.
Scooterlam wrote:The zen part of the book was a bit over my head, but the bits relating to the thought processes required to problem solve
Were quite enlightening.
its a big old book but well worth a read.
Recomended by users of the old forum.
berniek wrote:Have you checked the crank for alignment?
IaninDorset wrote:Better than most Vespa cranks lol
But would this cause your failure I am wondering? Even with a little play I can't see how that would stop it running as the piston is going to be in the "zone" fairly well enough to maintain running I would have thought.
Users browsing this forum: No registered users and 85 guests
