Scooterdude wrote:Found the answer to this if anyone needs information: the Wossner, Asso, Moss, Mitaka etc as intended for ts1/RB all share the same dome height of 7mm along with the BGM Meteor so in theory should all fit the RT without having to have the head re-profiled.
I did note however that the ring pig position of the Mitaka was just on the edge of the boost port, just a bit to close for comfort. (fine in a piston port RT).
Carry on...
Norrie Bodge wrote:Scooterdude wrote:Found the answer to this if anyone needs information: the Wossner, Asso, Moss, Mitaka etc as intended for ts1/RB all share the same dome height of 7mm along with the BGM Meteor so in theory should all fit the RT without having to have the head re-profiled.
Carry on...
Does the Monza piston fit in this same crown profile?
Users browsing this forum: roli150lam and 6 guests
