Fresco questions
Fresco questions
Postby Storkfoot » Sat Feb 16, 2019 9:49 am
I am in course of buying an under kickstart Fresco. It looks nice and straight and not badly pitted but it has been painted over in a red oxide.
What colours and finishes were they originally?
What purpose does the end cap serve too?
Re: Fresco questions
Postby Fred » Sat Feb 16, 2019 10:36 am
Mainly red or chrome. The cap on the end is to muffle it even more
Fred
Postby rossclark » Sat Feb 16, 2019 8:46 pm
I had a black one in the early 90s, the cap does quieten it down a bit and does allow you direct the plume of smoke sideways down or up as you like.
Postby Storkfoot » Sat Feb 16, 2019 9:03 pm
Does it dampen performance?
I recall the red ones. Not sure I could live with a red one though.
I thought the tailcan bit, even though it is not a separate part to the main body, may have been chrome but, sometimes, the memory plays tricks.
Postby missing lynx » Sat Feb 16, 2019 9:13 pm
The early ones were mainly all red as for performance they were more show than go lol the end cap should be held in by a large cir clip the muffler should be packed with exhaust wading
Postby rossclark » Sat Feb 16, 2019 10:46 pm
The ones with the cap like that had a square bridge type thing with a threaded bolt welded to then baffle plate, which was indeed retained by a large circlip, and the cap is retained by a nut
Postby Storkfoot » Sun Feb 17, 2019 10:17 am
rossclark wrote:The ones with the cap like that had a square bridge type thing with a threaded bolt welded to then baffle plate, which was indeed retained by a large circlip, and the cap is retained by a nut
That makes sense now. The one I had about 10 years back didn’t have that but was the same exhaust as this in all other ways.
It’ll be going on a very modestly powered engine, a Suzuki 190 conversion with either a 22 or 24 carburettor.
Postby Storkfoot » Mon Feb 18, 2019 9:17 pm
Postby rossclark » Mon Feb 18, 2019 10:41 pm
Like that ^
Postby Storkfoot » Mon Feb 18, 2019 11:21 pm
Picked it up tonight. Very good condition and clearly seen little use over the years. Sadly, it is missing the swan neck.
It’s given me some motivation to make a start on the engine.
Postby martyn dwane » Tue Feb 19, 2019 12:28 pm
If by swan neck you mean the part that bolts onto the casing and exhaust i think i might have one buried in my junk lambretta parts .
martyn dwane
Postby Storkfoot » Tue Feb 19, 2019 1:12 pm
martyn dwane wrote:If by swan neck you mean the part that bolts onto the casing and exhaust i think i might have one buried in my junk lambretta parts .
If you do and if you wish to part with it, that would be brilliant. Thanks.
Postby martyn dwane » Tue Feb 19, 2019 10:57 pm
tomorrow so will have a look, your welcome to it if i can find it.
martyn dwane
Postby martyn dwane » Wed Feb 20, 2019 6:34 pm
think this is it
martyn dwane
Postby Storkfoot » Wed Feb 20, 2019 7:30 pm
Yes, I agree. I am pretty certain it is.
Thanks. PM sent.
Users browsing this forum: Google [Bot], roli150lam and 3 guests
