Cut down rear runners
Postby shane BBoys » Sat Oct 13, 2018 7:02 am
Morning.
Do the series 3 cut off / shortened runners fit a series 2 ? If not who’s supplying series 2 aluminium or fibreglass?
Shane
shane BBoys
Re: Cut down rear runners
Postby Norrie Bodge » Sat Oct 13, 2018 7:12 am
Try here for fibreglass m8
http://www.grpscooterparts.co.uk/
Norrie Bodge
Postby shane BBoys » Sat Oct 13, 2018 2:53 pm
Norrie Bodge wrote:Try here for fibreglass m8
Ta,
shane BBoys
Postby gaz_powell » Sat Oct 13, 2018 4:05 pm
S3 cut off/shortened rear runners won't fit S2.
I've seen plenty of S3 one off the shelf, but when I wanted a set for S2 I had to make them.
Postby shane BBoys » Sat Oct 13, 2018 8:22 pm
gaz_powell wrote:S3 cut off/shortened rear runners won't fit S2.
Gaz.
Thanks for the heads up, ill speak to Chris as i am doing everthing i can in fibre glass, arse about face as per usual have the engine, in bits of caurse: frame & forks and panels ( fibre)
Shane.
shane BBoys
Postby gaz_powell » Sun Oct 14, 2018 10:34 am
Easy answer is cut down a set of F/G ones and get Chris to edge them (what I should have done) it's an expensive route but they will look good, I was never happy with my flat sheet metal ones bent (like off the shelf S3).
Are you still after S2 panel badges in vinyl....
viewtopic.php?f=19&t=86&p=300&hilit=S2+bitsa#p300
Postby shane BBoys » Sun Oct 14, 2018 7:32 pm
gaz_powell wrote:Easy answer is cut down a set of F/G ones and get Chris to edge them (what I should have done) it's an expensive route but they will look good, I was never happy with my flat sheet metal ones bent (like off the shelf S3).
Contacted chris with great success. Yes I am still after some.
Cheers Shane.
shane BBoys
