Leotech wrote:I've got a GP50 exhaust and over the winter I am going to modify it to use a slip joint stub manifold.
Its a chore as the U bend is constantly coming loose, its not a bad fit but it's not perfect and with the vibration etc. its always needing nipping up.
The extra slip joint will mean I get more tolerance on the fit as well, and its easier to whip the pipe off for servicing etc.
martyn dwane wrote:chain tensioner tab washer, cut the two round bits off,fit under the nut ,bend the tab, one on the nut side one on to the exhaust flange, as recomended by taffspeed so many years ago. use this method on my Mikec.
bike grim wrote:Leotech wrote:I've got a GP50 exhaust and over the winter I am going to modify it to use a slip joint stub manifold.
Did you ever do this modification? Interested to see the result
Users browsing this forum: Google [Bot] and 8 guests
