Psychedelicropcircle wrote:Silent blocks changed sitting a lot better. Chucked one of them casa flatside engine bolts in & my inlet was right up against the frame, was thinking I put in down side up! Thing can turn as you nip the bolt up! Anyhoo all sorted now!
holty wrote:i get what you mean, the main bar turned and so did the cones, thus moving the manifold closer to the frame
Psychedelicropcircle wrote:I didn’t hold the bolt first time round. Probably the best idea is to turn the fixed end till you have maximum clearance then hold in place whilst you nip up the nut.
Users browsing this forum: Google [Bot] and 14 guests
