kick start shaft
kick start shaft
Postby kennystag » Thu Aug 30, 2018 1:35 pm
Hi All,
I fitted new kick start shaft, spring, bushes, reference pin kit, when I fit the oil seal there is no room for the shim and circlip to fit in the grove in the casing, the new bushes are flush in the casing, how can I rectify this problem.
Stag
kennystag
Re: kick start shaft
Postby HxPaul » Thu Aug 30, 2018 1:59 pm
Hi.The circlip doesn't fit in the case,it goes on the end of the kickstart shaft.
Postby Warkton Tornado No.1 » Thu Aug 30, 2018 3:34 pm
Hi Kenny.
I sent you an e-mail reply.
(Sounds like you have a late kickstart shaft with an early case)
There is a 'fix' should that be the situation...... ;)
Postby kennystag » Thu Aug 30, 2018 3:54 pm
I know it does not fit into the case. A senior moment. Thanks Mark, I will have a look @ your email.
Stag
:lol:
kennystag
Users browsing this forum: Baidu [Spider] and 80 guests
